weatherstripping restoration #1419757
04/14/13 11:09 AM
04/14/13 11:09 AM
SE Pa.
LimeliteAero Offline OP
SE Pa.
I actually don't need restoration just something to make my door seals look fresh/new.
I just cleaned them up and they look very nice, I was just wondering if anyone had proven methods that will darken them up or make them look newer. They don't have any splits or cracks and are very supple so its just a matter of appearance.
Re: weatherstripping restoration [Re: LimeliteAero] #1419758
04/14/13 11:15 AM
04/14/13 11:15 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i was thinking along the same lines for my car.
most of my stuff is ok but weathered a bit.
i have already wasted enough time
in my life making repop parts fit properly..
Re: weatherstripping restoration *DELETED* [Re: flypaper] #1419759
04/14/13 02:13 PM
04/14/13 02:13 PM
Salem
Grizzly Online tonguue
Moparts Proctologist
Grizzly  Online Tonguue
Salem
Post deleted by Grizzly
Mo' Farts
Moderated by "tbagger".
Re: weatherstripping restoration [Re: Grizzly] #1419760
04/14/13 10:26 PM
04/14/13 10:26 PM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
I'd use 303 protectant. I'd avoid any product that contains petroleum products. 303 is recommended by more makers of vinyl, etc than any other.
Dave...if you need it...I have it.
Re: weatherstripping restoration [Re: MattMPA] #1419761
04/15/13 07:35 AM
04/15/13 07:35 AM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
I did the same with mine, reused. I cleaned with simple green to get all the dirt and grime off then when over them a few times with a vinyl/rubber conditioner. Nothing fancy, something from one of the parts stores.
I did replace most of the little 'L' clips as some broken when removed. Got them from rtspecialties.
383, Hemi 4-Speed, AlterKtion, D60
Re: weatherstripping restoration [Re: Crazy68Dart] #1419762
04/15/13 09:10 AM
04/15/13 09:10 AM
SE Pa.
SE Pa.
Thanks Matt & Crazy,
I did the Simple Green dance and they came up very good but I was looking to try and darken them up a little.
Matt, I knew not to use any petroleum based products. Does the 303 do anything for the rubber other than make it shiny? Can I use it on a vinyl top too?
Re: weatherstripping restoration [Re: LimeliteAero] #1419763
04/15/13 10:29 AM
04/15/13 10:29 AM
Ive used 303 only once on my tonneau cover on my truck and it left grayish / black streaks on the side of my truck. For keeping the gaskets dark and pliable, I would use some kind of a vinyl / rubber cleaner and conditioner like Meguiars number 40.
Re: weatherstripping restoration [Re: ] #1419764
04/15/13 01:35 PM
04/15/13 01:35 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
The number 40 sounds familiar... that may be what I used after the simple green cleaning.
Either way, the conditioner darkened them and made them shiny.
Re: weatherstripping restoration [Re: LimeliteAero] #1419765
04/15/13 09:49 PM
04/15/13 09:49 PM
Salem
Salem
Yep, the product I posted will do that. Yer welcome.
Mo' Farts
Re: weatherstripping restoration [Re: Grizzly] #1419766
04/16/13 09:36 AM
04/16/13 09:36 AM
SE Pa.
SE Pa.
Re: weatherstripping restoration [Re: LimeliteAero] #1419767
04/17/13 08:18 AM
04/17/13 08:18 AM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
Some folks report that 303 streaks...but it's because it was used incorrectly. 303 needs to be "buffed" with a dry cloth to avoid streaking and enhance longevity. (Dirty streaks are often from too much product, no buffing, and a dirty surface to start.)
303 will darken the surface, and protect it better than any other product...plus it's water based which is safer than a silicone product.
For the record, Meguair's #40 contains silicone.
I assume the car got a new vinyl top? Don't dress it with anything. It shouldn't be shiny anyhow. It's a huge area to dress and folks tend to apply too much to the top..and then all kinds of dust, pollen, etc stick to it. On my cars with new vinyl tops, I've never used a dressing.
You are welcome to look at my top, try 303, etc...just gimme a ring.
Re: weatherstripping restoration [Re: MattMPA] #1419768
04/17/13 05:57 PM
04/17/13 05:57 PM
Interesting about the Meguiars #40. It usualy washes off with water as a good rain storm comes and it is off my truck tires. I would have imagined if it had silicone in it, that it would have beaded the water off. Now the Black Magic Tire Wet has ruined my tire brushes since that will transfer to ANYTHING and not wash off!
Re: weatherstripping restoration [Re: ] #1419769
04/18/13 03:46 PM
04/18/13 03:46 PM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes 303 - transformed my dashpad...and not shiny if you wipe/buff it off
