As always, read the attached........
http://www.440source.com/blockinfo.htmAs for the replacement of the 915's to 452's......who knows what was going through the previous owners head when that happened. Not worth wasting your time, they're gone.
Now you have the best of two open chamber heads. Most here will tell you to upgrade to aftermarket aluminum (Stealth's or Edelbrocks) but that's your call. It's still several hundred cheaper to do the 452's.
As for block inspection.......I'd look for cracks in the intake valley from water/coolant freezing and on the outside at the coreplugs. Very common.
If you can pull the heads, look for a clean deck surface, no burnthru cyl.-to-cyl. from a blown headgasket. Obvious cracks in the bores or main saddles. After that it's a gamble until the sonic test. If the bearings all still hold themselves in and don't fall out when you pull the caps it's a good sign that it wasn't detonated and spark knocked to death. This breaks ringlands and beats the rods out-of round at the big end. If the bearings look clean and no gouges/grooves from grit and dirt it's another good sign.
The bearing usually have a date on their backside too. This will clue you in on if it's original or it's last refresh/rebuild.
Good luck.
