P9 mopar head #1418930
04/12/13 08:38 PM
04/12/13 08:38 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Some pictures more info. Later.... ;-)
Re: P9 mopar head [Re: W5DART66] #1418931
04/12/13 08:42 PM
04/12/13 08:42 PM
Renton Washington
Triple Threat Offline
Renton Washington
Such a tease!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: P9 mopar head [Re: W5DART66] #1418932
04/12/13 08:45 PM
04/12/13 08:45 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Man, Brett, you've contributed a ton of info here. You're the best. Thanks
Re: P9 mopar head [Re: Leigh] #1418933
04/12/13 10:01 PM
04/12/13 10:01 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
what block is that?
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: P9 mopar head [Re: 440W8 Duster] #1418934
04/12/13 10:27 PM
04/12/13 10:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mine, r3 9.00 deck dry sump, 4.200 bore and more meat to go bigger. For sale pm me.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: P9 mopar head [Re: 1967dartgt] #1418935
04/13/13 12:30 AM
04/13/13 12:30 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Now that's something you don't see on here everyday. Looks veerwy intewesting
Any intakes for 9.56 deck height?
Re: P9 mopar head [Re: 72demon416] #1418936
04/13/13 01:00 AM
04/13/13 01:00 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I think intakes are all sheet metal for these....I am not aware of anything being cast.
I thought you needed an R-4 block with these ?
If they did bolt up to an R-3 , you would need to re-locate lifter bores I think.........yes ?
I seem to remember something else unique to these......timing cover and drive C to C distance maybe ? ( R-4's )
Re: P9 mopar head [Re: Triple Threat] #1418937
04/13/13 01:34 AM
04/13/13 01:34 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Such a tease!
Re: P9 mopar head [Re: sixpackgut] #1418938
04/13/13 07:55 AM
04/13/13 07:55 AM
Finland
mafo Offline
mafo  Offline
Finland
Now that is different, is that a injector bung inside the valve cover
It s kind of like a P5 but...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: P9 mopar head [Re: mafo] #1418939
04/13/13 10:14 AM
04/13/13 10:14 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I wonder if they crack in the bowls like the P5's do?
Alan Jones
Re: P9 mopar head [Re: LA360] #1418940
04/13/13 11:15 AM
04/13/13 11:15 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
This head was designed for midget racing (4cyl).
It shares alot with the non hemi head p5 this is just light weight casting.
Yes they are injector bosses in top of intake runner.
No cast intake for this head like to see how p7 lines up or maybe big LS C5R intake.
The other big down side is set of castings will set you back about 5k
Right now in take is at 3" right now I am gong to try to get 4" cross section.
Re: P9 mopar head [Re: W5DART66] #1418941
04/13/13 05:20 PM
04/13/13 05:20 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice work have you ever worked on a G3 head? Matt
