Undercoating/Underseal 68 superbee #141847
10/26/08 07:49 PM
10/26/08 07:49 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
I'm doing a little detailing on my car this year and my question regards the corosion undersealing
If the underseal was applied at the factory would it be body color?
My underseal is black but the car is blue.
Could this mean the underseal was applied later?
I'm unsure what to do
Keeping the Bee Buzzin'
Re: Undercoating/Underseal 68 superbee [Re: Simonic] #141848
10/26/08 08:02 PM
10/26/08 08:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
under coating was NOT applied at the factory. It was either applied at a company where the vehicles came of the rail road cars to be cleaned and preped for distribution to the dealers or at the dealerships them selfs.. it was black..
I am truckless..
Re: Undercoating/Underseal 68 superbee [Re: Simonic] #141849
10/26/08 08:06 PM
10/26/08 08:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The undercoating was applied after the cars were painted. So long as the remaining undercoating is still adhearing to the car you can apply more right over top of it although it will make the old undercoating look really dull. If it's a pretty visable spot you'll want to apply it over the entire area so it looks even.
RestoRick sells the undercoating that resembles the factory texture, but you do need a special gun to spray it.
Re: Undercoating/Underseal 68 superbee [Re: 340SHORTY] #141850
10/26/08 09:18 PM
10/26/08 09:18 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
it was black..
Does this apply to the wheel wells also?
Re: Undercoating/Underseal 68 superbee [Re: Simonic] #141851
10/26/08 09:21 PM
10/26/08 09:21 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
it was black..
I am truckless..
Re: Undercoating/Underseal 68 superbee [Re: 340SHORTY] #141852
10/26/08 09:32 PM
10/26/08 09:32 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Thank you gentlemen you've been most helpful
Re: Undercoating/Underseal 68 superbee [Re: Simonic] #141853
10/27/08 05:32 PM
10/27/08 05:32 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
From what I've observed, the stuff in the trunk that looks like undercoating (I guess it was to protect the quarters from dings) was applied before the quarters were welded to the car, therefore, they were painted. The wheelwell undercoating was applied after paint, but before suspension, so it is always black. The general undercoating is applied after assembly, I think, because I see it on things like the parking brake and gas tank. Someone said it was not applied by the factory? Is it done as a factory option, but done by a vendor like the Hurst cars and Daytonas, or is it a dealer option?
Re: Undercoating/Underseal 68 superbee [Re: 375inStroke] #141854
10/27/08 05:55 PM
10/27/08 05:55 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
I did wonder how this would work?
I suppose if it was a factory option and done by an outside vendor there could have been some mention of it on the option list?
Or if it was done at the dealer it could just have been a case of the dealer offering the undercoating at the time of sale in which case it would not appear on any factory paperwork??
Re: Undercoating/Underseal 68 superbee [Re: Simonic] #141855
10/27/08 08:41 PM
10/27/08 08:41 PM
WI
RestoRick Offline
RestoRick  Offline
WI
All cars received wheelwell undercoating that was applied after paint.
As mentioned sound deadening on the inside of quarter panels (& doors), was applied before assembly on the car and was painted over.
Cars ordered with the J55 sound deadening package received additional undercoat on the floor pans and an underhood pad (on non fresh-air hood equipped cars).
All of the above were applied at the factory.
Dealership & aftermarket applied undercoating was usually a thinner & smoother appearing material.
Rick
