I have both style masters and I was checking the same thing as you and my answer is no.
The reason is I think the caps will fit each master BUT the 1/4" bolt will not give you enough room to tighten it on the cap designed for the 5/16" bolt. The camel hump bracket is bent for a 5/16" bolt to fit in the valley so the head on the 1/4" bolt won't let you get a socket or wrench on it to tighten it down.
My memory isn't what it used to be but I believe this to be true.
I checked this out about a year ago.
David
