Head Gaskets Block Coolant Passages #1418034
04/11/13 01:54 AM
04/11/13 01:54 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I bought a set of Mr Gasket steel shim gaskets for my 440 with Stealth heads. When checking the fit around the combustion chambers I noticed a severe blockage of some of the coolant passages. I'm thinking Whiskey Tango Foxtrot, stupid aftermarket junk. So I dragged a 906 out from under the bench, same deal. Stupid Mr Gasket [Edited by Moparts - Family Friendly Site - Keep it clean]
So I got out one of the fel pro 8519PTI gaskets (standard gasket) and guess what? Same deal, worse actually. I wish I kept my original head gaskets to compare, the witness marks on the 906 heads from the original 1967 date coded gaskets look like it wasn't interfering before but of course the marks are from the embossings.
I ran a set of that same gaskets I believe when fixing a burned valve on a buddy's 383 over the summer. I had bought them 3 years ago, but it was the same kit. I'm ashamed to say I never checked the fitment to the head, or if I did I don't recall seeing this, but it was the same kit and I assume the same gaskets.
Is this okay? Should I mod the gasket? Anyone else know anything or noticed this before? I can't be the only one. I don't see how it could be okay its blocking a head to block passage, but my buddy's 383 didn't have any cooling issues.
On a side note my first combustion chamber CC'd 79 cc
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418035
04/11/13 01:55 AM
04/11/13 01:55 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Pic 1
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418036
04/11/13 01:55 AM
04/11/13 01:55 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
pic 2
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418037
04/11/13 01:56 AM
04/11/13 01:56 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
pic 3
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418038
04/11/13 02:59 AM
04/11/13 02:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The restrictions in the gaskets are there to slow the coolant down so the there is better heat transfer to the coolant.
I am truckless..
Re: Head Gaskets Block Coolant Passages [Re: 340SHORTY] #1418039
04/11/13 03:16 AM
04/11/13 03:16 AM
OP, your good, put them babys on
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418040
04/11/13 06:35 AM
04/11/13 06:35 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree install them.Why try to out figure the factory engineers.Rocky
Chrysler Firepower
Re: Head Gaskets Block Coolant Passages [Re: therocks] #1418041
04/11/13 07:29 AM
04/11/13 07:29 AM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
Those big holes are sized that way to get the sand out of the casting in the foundry. This is true of both the block and the heads as they are "sand castings". The gasket reduces them to what they should be for cooling. I never tried opening them all up to the casting size to see what would happen.
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418042
04/11/13 10:31 AM
04/11/13 10:31 AM
go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns' cooling mods that are in a sticky at the top & that info may better help you make an informed decision. He's a SB guy but the info is still applicable to BB's with some differences.
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418043
04/11/13 10:37 AM
04/11/13 10:37 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Are you sure you're supposed to use steel shim type gaskets with aluminum heads?
Re: Head Gaskets Block Coolant Passages [Re: 80fbody] #1418044
04/11/13 10:44 AM
04/11/13 10:44 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
You're not supposed to but many guys are running them and getting away with it. I think with the superior head clamping design of the Chrysler big blocks and Chevrolet small blocks and big blocks that most people would be fine (17+ head bolts rather than 10).
I'll probably copper spray them, although the instructions say that you shouldn't because they already have a coating on them. It looks like they're aluminum painted.
And thanks guys, I guess I've never actually really looked at this before. I figured its supposed to be since both gaskets were this way, but it didn't make sense. Since my detective at Moparts have explained the reasoning I feel comfortable with them now. Thanks
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418045
04/11/13 10:47 AM
04/11/13 10:47 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'd be more concerned with the the steel gasket ruining the head surface but I've never run aluminum heads.
Re: Head Gaskets Block Coolant Passages [Re: 80fbody] #1418046
04/11/13 10:50 AM
04/11/13 10:50 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I've heard this noted before, but theres quite a few threads on here about steel gaskets with aluminum heads. They say multi-layer steel is okay, so what difference would that make on the surface of the head that the regular steel shim wouldn't? Not being a wise guy, just wondering if you'll learn me something new
Re: Head Gaskets Block Coolant Passages [Re: GTX MATT] #1418047
04/11/13 11:25 AM
04/11/13 11:25 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Dis-similar metals, aka steel & aluminum, don't generally mix well. Not sure the technical term but over time the steel sort of eats into the aluminum head surface. Also the steel gasket is a harder material than the aluminum head which means the gasket could imprint itself into the head.
Doesn't seem worth the risk with high dollar heads.
Re: Head Gaskets Block Coolant Passages [Re: TooMany62s] #1418048
04/11/13 11:38 AM
04/11/13 11:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I agree with this but the fly in the ointment is that around 1973 they changed the holes in the block to a figure 8 shape which ends up having a round hole right in line with the round hole in the head, BUT they changed the gasket from the rectangle to a slit.
Re: Head Gaskets Block Coolant Passages [Re: 80fbody] #1418049
04/11/13 11:40 AM
04/11/13 11:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
BUT BUT BUT ....
People run MLS Cometic gaskets with alum heads ??????
The fire ring , if that is what it is called , on a felpro gasket is STEEL ????
Coat the gasket with copper spray and he should be fine ...
Re: Head Gaskets Block Coolant Passages [Re: 80fbody] #1418050
04/11/13 07:51 PM
04/11/13 07:51 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's called bi-metallic corrosion.
I wouldn't sweat it if you use coolant and not straight water as the coolant has corrosion inhibitors. Also, it really doesn't matter what head gasket you use, in regards to corrosion, they all will have a dissimilar metals issue.
Don't be the exception.
Re: Head Gaskets Block Coolant Passages [Re: 80fbody] #1418051
04/12/13 01:13 AM
04/12/13 01:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can't ... resist ...
He doesn't have High Dollar Heads ...
Re: Head Gaskets Block Coolant Passages [Re: JohnRR] #1418052
04/12/13 03:31 AM
04/12/13 03:31 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Ive been running a set of steel shims under alum heads for 6+ yrs now with no problems at all.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Head Gaskets Block Coolant Passages [Re: JohnRR] #1418053
04/12/13 11:22 AM
04/12/13 11:22 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
HEY
I was actually going to say that myself, but I guess 1000 bucks is more than a stock set of 906 costs in most cases
