Where can I get a 65 slant 6 passenger side motor mount #1417781
04/10/13 02:54 PM
04/10/13 02:54 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
The free Belvedere I got needs a passenger side motor mount for a slant 6 cant find one anywhere. Autozone had one but was wrong. Mine has studs on both sides and the AZ one had studs and flanges.
Rock auto also shows the wrong ones.....
Figured it out it has 64 style motor mount in it and these are available and cheap
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Where can I get a 65 slant 6 passenger side motor mount [Re: HemiRick] #1417782
04/10/13 03:00 PM
04/10/13 03:00 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
I bought the same thing from Rock Auto for my /6 '65 Coronet wagon that didn't fit. I ended up buying NOS, off of ebay to get what I needed. It cost me about $20 + shipping.
Re: Where can I get a 65 slant 6 passenger side motor mount [Re: HemiRick] #1417783
04/10/13 09:03 PM
04/10/13 09:03 PM
Ridgecrest, Ca.
Ontos Offline
Ontos  Offline
Ridgecrest, Ca.
I have a set left over from a '62 Savoy /6. Lemme dig 'em out and I'll post a pic. See if they're the same.
Re: Where can I get a 65 slant 6 passenger side motor mount [Re: Ontos] #1417784
04/11/13 11:05 AM
04/11/13 11:05 AM
N.E.Ohio
P
Polarabill Offline
Polarabill  Offline
P
N.E.Ohio
Try Summit Racing, I got 65 A body,V8 mounts there a couple of weeks ago.
This would be so much easier if I knew what I was doing...
Re: Where can I get a 65 slant 6 passenger side motor mount [Re: Polarabill] #1417785
04/11/13 11:47 AM
04/11/13 11:47 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1964-1965 Belvedere 6 is the application
2264675 LEFT 31-2235 has 2 studs on 1 side and 1 stud on the other
2264674 RIGHT 31-2234 has two studs on 1 side, 1 stud on other&wrap around flanges or saddles on 1 stud side
which do you need?
Re: Where can I get a 65 slant 6 passenger side motor mount [Re: Joesixpack] #1417786
04/11/13 11:52 AM
04/11/13 11:52 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1962-1963 6 are the same....
