Page 3 of 3 1 2 3
Re: E-Body leg room, or lack of... [Re: HEMIDOG 70] #1416224
04/13/13 04:32 PM
04/13/13 04:32 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Man they always feel large to me like i am sitting on the floor and the seat is up {not all the way up towards the wheel but up some}
Being small has benefits 5'4" 125 or less pounds lets me work under cars well, and under a dash as well
Sounds like Ya need a 6 way seat
Even the back seat was ok with me in a friends challenger's
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: E-Body leg room, or lack of... [Re: screamindriver] #1416225
04/15/13 01:17 PM
04/15/13 01:17 PM
pa.
dan9 Offline
dan9  Offline
pa.
So someone could use a Grant aftermarket wheel and still use a crush can?
Re: E-Body leg room, or lack of... [Re: filmsurgeon] #1416226
04/15/13 05:40 PM
04/15/13 05:40 PM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Some of you have sent me PMs asking questions. I have responded to all, but I also like to share the info with those who have been following this topic. Here are some more photos and info. Take note: each photo's file name is unique, and the photo(s) will be preceded by a description.
Let's start with the bracket/screw.
Each bracket has a front and rear hole drilled for a 5/16" screw/bolt. Only one side of one hole is countersunk for the 5/16-18 flathead hex stainless screw. The bracket measures 2-7/8" long (it can be made longer if desired), and is 1" wide and 3/16" thick.
My seat tracks are currently disassembled for cleaning/painting/lubing. Fortunately, this helps to better see how the brackets work with the seat tracks/seat frames. Photos are of the driver's seat bottom and upper track halves. When using these brackets, there is NO drilling required into the floor, seat frames, or seat tracks. This means you can go back to stock easily and without any molestation to your car, seats, and tracks. They only work between the seat track and the seat frame. Trying to make brackets work inside the track opens up a whole host of issues to overcome. There is no interference with the travel of the seat tracks when the brackets are located between the seat frame and seat track.
Inboard Track:
First is without brackets, and second is with brackets.
Outboard Track:
First without brackets, and second is with brackets.
With the countersunk hole and the flathead screw, there is only an increase in seat height of 3/16". That's because of the bracket being located between the track and seat frame. The following photos show how/where the brackets are attached. This is done BEFORE the tracks are mounted to the bottom of the seat. You can't do it any other way.
Brackets attached to FRONT of seat frame:
The next 4 photos show how the front of the tracks are attached to the front brackets.
Brackets attached to REAR of seat tracks:
The next 4 photos show how the rear brackets are attached to the seat frame.
I believe the original bolts used to attach the seat tracks to the seat frame have a 7/16" hex head. I only had these bolts on my passenger seat (I used them to attach the rear brackets to the seat frame for the photos). Standard 5/16-18 bolts ALWAYS have a 1/2" hex head. If you use standard bolts, it will be difficult to get a socket into the seat track and onto the 1/2" bolt head to tighten it. That's probably why the manufacturer used bolts with a 7/16" head. No problem with using a socket on this. The previous owner used standard 5/16-18 bolts with a 1/2" hex head on the driver's seat. I had a very hard time finding 5/16-18 x 3/4" bolts with a 7/16" hex head. Then I stumbled across these bolts in the following photo. They are cheap for a set of 10 and they are hardened steel.
One other note: You should file/grind down the two nubs behind the mounting hole on the front of the seat track. This will allow the bracket to be flush with the track when mounted. The following shows the front of the passenger's seat tracks. These nubs are NOT filed down, but they are on my driver's seat tracks.
Re: E-Body leg room, or lack of... [Re: dan9] #1416227
04/15/13 10:02 PM
04/15/13 10:02 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Actually it's grant's E-body adapter{can} for their wheel..They even offer a "plymouth" center cap...
Re: E-Body leg room, or lack of... [Re: filmsurgeon] #1416228
04/16/13 07:53 AM
04/16/13 07:53 AM
GA
roadrunninMark Offline
GA
Thanks for the great tutorial, Film. I've got it now!
Re: E-Body leg room, or lack of... [Re: screamindriver] #1416229
04/16/13 11:17 AM
04/16/13 11:17 AM
pa.
dan9 Offline
dan9  Offline
pa.
Thank you for the info!
Re: E-Body leg room, or lack of... [Re: dan9] #1416230
04/17/13 06:47 PM
04/17/13 06:47 PM
Oklahoma
TinCuda Offline
TinCuda  Offline
Oklahoma
Nice write up.
(O O {]{]{]||[}[}[} O O) 1971 Plymouth 'Cuda 440-6 {||O||} 2000 Yamaha V-Max (O O [========= SRT] O O) 2011 Dodge Challenger SRT 392 . Making as big as a carbon footprint as I can!!!
Re: E-Body leg room, or lack of... [Re: screamindriver] #1416231
04/18/13 02:17 PM
04/18/13 02:17 PM
Michigan, Planet Earth
4cruzin Offline
4cruzin  Offline
I used the grant wheel and the regular crush can with minimal work . . I like the look and the wheel is a little smaller than the regular tuff wheel so getting under it is not that hard. I also am a large person at over 260 and 6'4" and I don't feel jammed in the car at all??
Mopars Rock
Re: E-Body leg room, or lack of... [Re: 4cruzin] #1416232
04/23/13 09:59 AM
04/23/13 09:59 AM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
I made brackets just as filmsurgeon posted, I made them 2" from hole to hole so I would gain 2" in seat placement.
Well it all seemed like a good idea but their is a problem. You can not slide the seat back that much further because it hits the seat belt retractor. I think all I gained was about 1" until it the retractor. Looks like I am going to have to go to a smaller wheel.......
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: E-Body leg room, or lack of... [Re: Mopar_Mudder] #1416233
04/25/13 03:00 AM
04/25/13 03:00 AM
California, USA
filmsurgeon Offline
filmsurgeon  Offline
California, USA
Interesting. I hadn't experienced that issue when my seat were in the car. However, the prior owner did NOT have seat belt retractor covers installed, and I found that he had relocated the driver's belt retractor almost a full 2" closer to the door.
Re: E-Body leg room, or lack of... [Re: filmsurgeon] #1416234
04/25/13 10:10 AM
04/25/13 10:10 AM
Wisconsin
Wisconsin
If the covers were not on it was probalby not a problem. But with the covers on it will be an issue.
I don't see any good way to move the retractor back now. Would be easy enough before the car was all painted, but not now.
Re: E-Body leg room, or lack of... [Re: Mopar_Mudder] #1416235
04/25/13 12:40 PM
04/25/13 12:40 PM
Sec.414,seat 12,White Sox Park
swapman Offline
swapman  Offline
I understand you are rebuilding a 1971. If so, just make a new backing plate with bolt hole. Weld to bottom of floorpan two inchs farther back. That is what I did.
Now if it is a 1970 with the plastic covers, a lot more difficult, especially if it has carpet already.
On my 1971 cuda we cut the floor board and moved the whole section back 3 inches. The part that was removed we welded in front of seat area. Worked great. I can now drive from near the back seat if so desired.
On my 1970 cuda I will have to make some more modifications because of what you say. Good luck.
Re: E-Body leg room, or lack of... [Re: swapman] #1416236
04/25/13 12:50 PM
04/25/13 12:50 PM
Wisconsin
Wisconsin
Not very practical when the car is all painted and done. Now if I had known this before the fact I would have moved it back when I was replacing the floor......
Re: E-Body leg room, or lack of... [Re: Mopar_Mudder] #1416237
04/25/13 02:20 PM
04/25/13 02:20 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 70' Challenger does not have stock seats. I have Kirkey racing seats & we made brackets to move the seats all the way back to the cage main hoop & we made a customer longer tubular steering column to move the wheel further back to my liking, also adapted the factory woodgrain wheel to the removeable adapter. This helps making getting in & out & may help out larger drivers as well even without a cage.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: E-Body leg room, or lack of... [Re: Mopar_Mudder] #1416238
05/06/13 10:01 AM
05/06/13 10:01 AM
Wisconsin
Wisconsin
Wanted to update that this week end I pulled the seat belt retractor off and was able to drill anther hole in the retrator that moved it 1" further to the rear of the car. This let the seat come back another 1". Now between the two mods I think it is accepteable with the oringinal wheel still on it and I can drive it. Smaller wheel would be better yet but I want to keep the original.
Page 3 of 3 1 2 3
