E-Body leg room, or lack of...
#1416184
04/07/13 08:23 PM
04/07/13 08:23 PM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
Got the Cuda to the point for the first time where I could actually sit in it with seats, steering wheel and the whole works Well so my surprise these things really were made for really short people!!! I am 6'3" and I have to sit spread legs in their and try to get the the clutch is a real pain. I can't believe they were designed that pourly, I can bearlly get my leg between the seat and steering where. Worse the getting in the 69 Vette, but that is comfy once you get in. Any way what are my options. I know the Tuff wheel is a little smaller, but I don't know if that is going to be enough. And it looks like they never came with tilt.
Re: E-Body leg room, or lack of...
[Re: Mopar_Mudder]
#1416185
04/07/13 08:28 PM
04/07/13 08:28 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Six way seat slightly tilted back... Or I've known of guys to knock the studs out of the seat track & relocate them to shift the seat rearward... This requires some minor fab work...
[Re: Mopar_Mudder]
#1416196
04/08/13 03:19 PM
04/08/13 03:19 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Wondering how exactly the 6 way helps? All it does is raise and lower the front and back of the seat correct? I don't see where either would help unless it drops the seat down in the front further, but I don't think that is possible.
I put a 6-way in my 73 Challenger, and it adds a lot of legroom. I'm 5'10 with short legs and with the standard seat tracks, I had my seat all the way back. With the 6-way addition, I have the seat about halfway forward. Also, by adjusting the front of the seat up, and the back down, you will gain headroom. I also have a Tuff wheel.
I've had some of my large size Mopar friends sit on the 6-way, and they are amazed at the additional head and leg room.
Find someone with a 6-way and ask to try it. You will be pleasantly surprised...
[Re: 318 Stroker]
#1416197
04/08/13 05:37 PM
04/08/13 05:37 PM
Mopar_Mudder
Wisconsin
I am going to have to look for one. I have looked a little bit and they seem really spendy!!!
Also I noticed mension on one place that the braces under the floor might be diffrent for the 6 way, I can't imagine they used a different floor for them.
[Re: Mopar_Mudder]
#1416198
04/08/13 05:43 PM
04/08/13 05:43 PM
318 Stroker
St. Louis, Mo
Yes they are spendy...
They are being re-popped. Some of the originals get worn, like mine is. Sometimes when I'm driving, it likes to "self-adjust" backwards a notch, on its own... The new re-pop probably wouldn't do that.
As for the underfloor braces, the regular seat tracks don't have any. Just the 6-way has the braces...
[Re: 318 Stroker]
#1416199
04/08/13 05:50 PM
04/08/13 05:50 PM
Mopar_Mudder
Wisconsin
Is their any problem with not using the under floor brace? The car is done and painted on the underside so I am not about to change it. I am guessing they were spot welded to the under side of the floor.
[Re: Mopar_Mudder]
#1416200
04/08/13 05:55 PM
04/08/13 05:55 PM
318 Stroker
St. Louis, Mo
Could be a big problem if you don't use them. The 6-way is heavy, and you could rip thru the floor with the stud mounts on the 6-way. The braces are re-popped. Either B,E A or RestoRick has them, I forget which.
They do not weld to the floor. Just paint them to match the underside, hold them in place as you drop the 6-way studs through, put the washers and nuts on, tighten them, and enjoy...
Disclaimer: Maybe they were welded from the factory, But I didn't weld mine. I just installed them as I described.
[Re: Mopar_Mudder]
#1416202
04/08/13 06:21 PM
04/08/13 06:21 PM
318 Stroker
St. Louis, Mo
What about the height of the 6-way set-up. I have been searching some and it looks like it adds some height to the seat, reducing head room. This would make sence I guess as their must need some height for all the mechanics under their. I guess if all I am gaining is that the 6-way will slide back further (do they) I might as well try to mod my standard brackets to go back further......
Yes they do add some height, but by adjusting the rear of the seat downward, you you not only get a liitle bit of recline, but regain the height you lost with the higher 6-way unit. My tall Mopar friends have plenty of headroom that way.
