Re: msd ignition
[Re: jeff500]
#1416075
04/07/13 07:18 PM
04/07/13 07:18 PM
Posts: 4,872 connecticut
pnypwr
connecticut
use the power wire to your coil.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
Re: msd ignition
[Re: jeff500]
#1416077
04/07/13 08:53 PM
04/07/13 08:53 PM
RapidRobert
Make sure it's getting full 12V not reduced voltage in the ign2 "crank" brown wire circuit and in the ign1 "run" blue wire circuit. when adding MSD I'm not sure if you bypass the ballast on strickly the coil ign1 "run" blue wire circuit IF keeping the original coil. I think there was some good info posted on this awhile back. Anyone? Does your 87 dak have a regular type electronic ign (ECU/ballast/2 wire dist pickup)
Re: msd ignition
[Re: jeff500]
#1416081
04/08/13 05:44 PM
04/08/13 05:44 PM
RapidRobert
do you have an ECU and a 2 wire pickup dist?
Re: msd ignition
[Re: RapidRobert]
#1416082
04/08/13 07:37 PM
04/08/13 07:37 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
there is no ballast resistor. and there is no advance mechanism on any magnum distributor. 12v to the msd and you will need an aftermarket or early distributor if you are changing it to carb. all the advance in the magnums comes from the ecu, and the ecu may not like the msd. id call msd and get their recommendations.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
