Re: unported 915s vs. ported 906s
[Re: Dean_Kuzluzski]
#1415761
04/07/13 10:21 AM
04/07/13 10:21 AM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
The ported heads will out perform unported heads even with the compression change. You could have all the compression in the world but if the heads don't flow that compression is wasted.
[Re: DGS]
#1415762
04/07/13 10:44 AM
04/07/13 10:44 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I think the compression difference is only about .6 a 906 will out flow a 915 by a bit anyways a well ported head will make a lot more power. and make way better use of a bigger cam, intake and headers/exhaust. and be a bit more fuel friendly. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: DGS]
#1415765
04/07/13 11:43 AM
04/07/13 11:43 AM
Posts: 5,167 CT
GTX MATT
CT
I'd run the 509 with the 906 heads. Those ports look pretty nice.
[Re: DGS]
#1415769
04/07/13 04:43 PM
04/07/13 04:43 PM
RapidRobert
As said you'd lose a slight bit of CR but gain ALOT of flow going from the unported 915's to the ported 906's. I'm assuming you dont have quench with the 915's but if you do have .040" quench I'd for sure stay with the 915's. Why are you wanting to lower the CR? Is pinging forcing you to compromise the adv curve? I'd keep the 915's as the ported 906's wont be cheap & if I wanted to step up I'd go with a set of mildly ported/blueprinted eddy or source alum heads which would give way more flow & the alum would likely solve the pinging issue
[Re: DGS]
#1415771
04/07/13 05:13 PM
04/07/13 05:13 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
When you pull the heads check the depth "in the hole" if they are zero great you had quench & it wasn't enough... Lowering it should help... But if they are .020 in the hole changing the a steel shim gasket might be your best option... sure it'll raise the compression slightly but you'll gain quench... To be pinging with a .509 cam & 93 octane you must be running some pretty good compression...
[Re: DGS]
#1415772
04/07/13 11:30 PM
04/07/13 11:30 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
If you can get your quench to .035-.040 with the 915 I would stay with them. If the quench is .060-.080 it with ping like a SOB, if you cannot correct that then the 906, eddy 440 source heads would be the way to go. The 906 you show need $500 spent on them for valves, valve job springs, retainers, at least so if you get them cheap maybe. I would not waste my time for how cheap the eddys are, plus you get hardened exhaust seats, but that is your choice, do the math.
[Re: dogdays]
#1415777
04/09/13 01:21 PM
04/09/13 01:21 PM
Posts: 170 renton , washington
perfmachst
renton , washington
hi, all 906 heads are not the same!!!! there is a R, M ,F and rare C letter cast on underside of intake runner.on a flow bench, at .500 lift all are pretty close same flow.. in the mid lift area, -.100 to.400 is where the main difference is.the flow curve has a noticable hump in the curve. mopar race manual states, the head with humped curve will provide more air to cylinder.as for flow , the R is the least the C is the best. most are usually M or F. so it runs, R,M,F,C, I have had all on a flow bench and used on various engines.
