Tiger stripes in my Matte/Flat clear...What the heck?? #1415714
04/07/13 02:05 AM
04/07/13 02:05 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I'm finishing up with the paintwork on a 72 Duster. Inferno Red body with a Matte Black performance paint treatment. The Matte/Flat clear coat I laid down has what can be described as tiger stripes in the clear. In reality, there is alternating levels of sheen as if the clear is still drying.
I sprayed it yesterday during a daytime temperature of 75 degrees. I laid on 2 medium coats with a 50 % overlap using the same cheapie harbor freight gun that I have used many times before. It is a gravity feed gun with a 1.5 tip. I get NO tiger stripes using these guns, even shooting metallics or pearlcoats. This clear is a PPG product that has given good results in the past.
My instincts are to wait it out, thinking that as the clear cures, it will flatten out. I suspect that the glossy areas will dull down as they fully dry. I obviously won't be satisfied with an uneven finish. I am curious as to what can be done if the situation doesn't improve. I cannot pinpoint what caused the striping other than my IMperfect painting skills, so a respray could return the same results. Can the surface be dulled down by other means?
What do you guys think?
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415715
04/07/13 02:24 AM
04/07/13 02:24 AM
nj
N
notforsale440 Offline
N
nj
ive use SEM hotrod black many times with zero issues..........looks great, holds up, and cleans up......cant stand ppg products
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415716
04/07/13 02:58 AM
04/07/13 02:58 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I'll bet it doesn't even out.
The flats and mattes can be tricky to do. I know pros who have issues with them. (I'm no pro). Dealt with it last summer on a hood - not so much stripes as splotchy results in one area using a single stage black. What worked: slight over-reduction and/or a slower reducer and spraying the piece in two directions. If the piece doesn't look evenly wet all over when you think you're finished spraying, it may not dry evenly.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: 70Duster440] #1415717
04/07/13 05:53 AM
04/07/13 05:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
wider spray pattern needed ??
I am truckless..
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: 340SHORTY] #1415718
04/07/13 06:17 AM
04/07/13 06:17 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I have thought about it several times. It seems that it all should blend and settle into a common sheen since all of the product was mixed at the same time with the same materials.
The matte clear goes on shiny and dulls to the final sheen after drying. In theory, my thoughts are that the shiny areas are just taking longer to dry.
Thats what I hope is happening, anyways!
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415719
04/07/13 09:04 AM
04/07/13 09:04 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If not, maybe you an hit the matte area's with 2000 git paper to knock all the sheen down to a universal appearance?
**Photobucket sucks**
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: 70Cuda383] #1415720
04/07/13 11:49 AM
04/07/13 11:49 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
50% overlap is not enough for good flow out. I'd go with a 75% and not pull back for the final coat.
I bet at least some of what you are seeing is the overspray at the edges of the fan pattern that is drier when it hits.
Going in two directions (across stripe first pass, along stripe second pass) will help too.
If you are shooting hood/roof/deck, you should probably set up a step at the roof so you can comfortably shoot all three at the same distance.
2000 grit may fix it for you.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: RodStRace] #1415721
04/07/13 12:14 PM
04/07/13 12:14 PM
fresno ca
mikeysmopars Offline
fresno ca
I use the cheep guns on a lot of my paint work and the trick is understanding the materials. Clears and fine metallics you need a smaller needle & nozzle. You can buy ten of those harbor freight guns and all ten will spray different. I use a Sata for those final coat applications with a .08 setup.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415722
04/07/13 05:14 PM
04/07/13 05:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
My says the gun is not clean enough inside...has built up paint in it causing it not to flow enough material and air to get the paint to lay right.
Even if when you clean your gun thoroughly each time after painting it builds up and has to be soaked and cleaned well while it is apart to get it to flow enough air and paint sometimes.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Challenger 1] #1415723
04/07/13 09:50 PM
04/07/13 09:50 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Good point. Maybe I'll spray a test pattern next time on a piece of plywood. That should show if anything is wrong. I have other guns I can use too.
Todays report: Still showing stripes. I wet sanded with some 1500 grit paper since it is the finest grit I could get on a Sunday. I'm thinking that even with careful sanding, it may be impossible to get a consistant finish without any sand scratched spots. I'm resigned to some sort of respray. If I get similar results again this time, screw it... I'll just spray it with tradtional gloss clear and cut and buff to a shine.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415724
04/08/13 01:39 AM
04/08/13 01:39 AM
Waddell AZ
azblackhemi Online content
azblackhemi  Online Content
Waddell AZ
I have heard alot of people saying they have had good results with cheap Harbor Frieght guns. I have tried them a couple of times out of curiosity and yes they do put paint on ok but they do not compare to a quality SATA, Iwata Devilbiss etc. gun. There is a reason they cost $49. If you're spraying a forgiving type of paint or if you're going to color sand and buff a cheap gun will probably work but when you want the desired result straight out of the gun don't be cheap.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: Kern Dog] #1415725
04/08/13 10:04 AM
04/08/13 10:04 AM
west australia
8trackbee Offline
8trackbee  Offline
west australia
The best way i have found, and this was also Spies Heckers method, use a slow hardner and slow reducer, no matter what the temp.... what happens is the slow curing allows the flatting agents to rise to the surface and therefor an even apperance. Works every time!! What is PPGs recomendation on hardners to use, i bet they say fast and medium hardners are fine....
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: 8trackbee] #1415726
04/08/13 03:18 PM
04/08/13 03:18 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
As stated elsewhere here, maybe my 50 % overlap pattern may be too little. I have read elsewhere that a 75 % overlap is recommended on flat surfaces. I wasn't aware of the suggestion, but it makes sense. The flat panels are less likely to run and need more paint for protection.
Re: Tiger stripes in my Matte/Flat clear...What the heck?? [Re: 8trackbee] #1415727
04/08/13 04:18 PM
04/08/13 04:18 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
8trackbee and others have confirmed my suggestion: slow reducer, spray in two directions - make sure it still appears wet all over when done spraying (should with the slow reducer). In this case I think it has less to do with the gun you're using and more to do with technique. Spraying out a nice, glossy clear is easier.
