Rusty brake lines on a 1997 dodge ram. #1414732
04/05/13 12:26 AM
04/05/13 12:26 AM
southern illinois
Y
yellowscamp Offline OP
Y
southern illinois
Was changing the oil on my 97 ram today and noticed that the brake lines are pretty rusty. How concerned should i be about this. I thought that maybe I should replace them. If i do is ther a good place to get prebent lines or would i be better off trying to bend them myself. Any help would be appreciated.
Re: Rusty brake lines on a 1997 dodge ram. [Re: yellowscamp] #1414733
04/05/13 12:30 AM
04/05/13 12:30 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Just buy a quality double flare tool and tube cutter. Then you can make anything for cheap out of parts store lines etc. I bend line with my hands, some people like to use bending tools. You just have to be careful to make a radius so it doesn't kink.
I only buy prebent/flared if I'm using stainless. Some say stainless is too hard and doesn't seal well but I'm a fan of the durability.
Re: Rusty brake lines on a 1997 dodge ram. [Re: radar] #1414734
04/05/13 12:44 AM
04/05/13 12:44 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Ck with a dealer, a lot of those tubes are still available at a good price.
Re: Rusty brake lines on a 1997 dodge ram. [Re: yellowscamp] #1414735
04/05/13 08:38 AM
04/05/13 08:38 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Spray them down with oil for now to try to slow down the rust, that's what I do. It helps, imo.
Re: Rusty brake lines on a 1997 dodge ram. [Re: Challenger 1] #1414736
04/05/13 10:02 AM
04/05/13 10:02 AM
My hovercraft is full of eels
DaveKanofsky Offline
I'm changing the brake lines right now on my '99 Durango. The long one to the rear starting leaking, so I decided to change 5 of them that looked bad.
I was surprised how brittle and easy to snap the rusty ones were.
I got all of the one I needed from a dealer - Mancari's Chrysler in Oak Lawn, IL - Thanks Fasbird!
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: Rusty brake lines on a 1997 dodge ram. [Re: yellowscamp] #1414737
04/05/13 11:22 AM
04/05/13 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Be very concerned , I lost the front to rear line , it goes behind the tank , if you buy factory prebent , i did , you have to drop the tank to replace it. If you take it to a repair shop they will just route the line around the tank and it will look like bleep .
Re: Rusty brake lines on a 1997 dodge ram. [Re: JohnRR] #1414738
04/05/13 12:02 PM
04/05/13 12:02 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
...route the line around the tank.
I have done this on quite a few Rams for the rear line.Dropping the tank usually involves more effort than most people are willing to go through though.As long as it's tucked up in the frame and replaced all the way to the rubber line on the rear end it's not too bad and not seen anyway.
For the trucks I have worked on,they were pretty rusty overall and I'd guess the replacement section of brakeline may outlast the body of the trucks.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: Rusty brake lines on a 1997 dodge ram. [Re: GrnMagic77] #1414739
04/05/13 03:35 PM
04/05/13 03:35 PM
P
Paul_Fancsali Offline
P
Get coated or nickel lines the standard ones are total crap. The tags look like new and brake lines totally gone after 3-4 years!!
Re: Rusty brake lines on a 1997 dodge ram. [Re: Paul_Fancsali] #1414740
04/05/13 03:44 PM
04/05/13 03:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I just did the frt to rear line on my kids 99 Durango.Also did the 2 rears for the whl cyls.New cylinders also.I just ran the frt along the inside of the tank.You never see it.No way was I dropping the tank.Rears we bent and flared.No big deal.I probaly did a few hundred a year at work.A 25 foot length of steel line and my flaring tool.pretty easy and quick.If the rear line blows it will still stop.Just you are using the fronts.It will eventually drain the master though.Rocky
Chrysler Firepower
Re: Rusty brake lines on a 1997 dodge ram. [Re: therocks] #1414741
04/05/13 07:52 PM
04/05/13 07:52 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
Have a 96 Ram and the long front to rear line went out on me in 2005, but just spliced it at that time. Last year I went to a Dodge dealer and the only lines that were available from them were the lines on the rear axle. So I finally bit the bullet and bought a whole new set of stainless lines from EGR Brakes, fit perect. Funny thing is the lines came in a box from one of the mainstream brake line makers (dont recall who). But i called them afterwards and asked if they had lines for my truck and they said no , must have some sort of agreement on the pattern with EGR.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: Rusty brake lines on a 1997 dodge ram. [Re: VZCharger] #1414742
04/05/13 08:09 PM
04/05/13 08:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The 99 Durango we run has just about all the lines changed out now...The tranny lines are next...Some I caught in time and some I did'nt...I don't run it much and should give it some more of my time but it's old and the other vehicles seem to come first...
I did have the original rear brake lining come off the shoe !!! That was a real eye opener until I got it stopped...Spun and lodged into the other side...
Re: Rusty brake lines on a 1997 dodge ram. [Re: screamindriver] #1414743
04/05/13 09:33 PM
04/05/13 09:33 PM
southern illinois
Y
Y
southern illinois
Thanks for all the great replies. Looks like I am going to be doing a complete brake as one of the brake cylinders is leaking.
Re: Rusty brake lines on a 1997 dodge ram. [Re: yellowscamp] #1414744
04/20/13 05:01 AM
04/20/13 05:01 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
I had all of them done on my 97 Ram 1500. They were all pretty bad. While your under there check you gas tank filler tube. Mine started leaking shortly after the brake lines. After I changed it I crushed it with my bare hand it was so far gone. Got one off of ebay.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
