904 Transmission Rebuild Kit Questions?
#141427
10/25/08 08:10 PM
10/25/08 08:10 PM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
I'm fixing to have my 904 auto transmission rebuilt and needed some information before ordering. The current engine is pushing around 400-425 hp at the crank. I also have a 9" PTC 3500 stall converter. Lastly, I have the TCI Streetfighter shifter.
I'm looking for a tough yet reliable rebuild kit along with a shift kit. I want it to upshift and downshift right when you move the lever, with no lag. Any help would be much appreciated.
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: 904 Transmission Rebuild Kit Questions?
[Re: twister360]
#141429
10/25/08 11:25 PM
10/25/08 11:25 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
There is a guy that sells billit pistons in the race parts section, get them all and get the ones that prevent movement of the accumulator.
Also I like to use the 5 clutch front drums and 4 in the rear clutch with all flat snaprings, no wavys any where in the trans. Use the TF2 kit for an auto shift and TF3 for manual shift. When drilling the holes in the seperator plate go to the maximum size, it will not be too hard of a shift.
[Re: cudabitten]
#141432
10/27/08 02:57 PM
10/27/08 02:57 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
Wow, can a 904 really handle that much horsepower?
yes it can, its the torqe i would worry about. But if its built good it should handle it..
