Re: throttle/kickdown bracket
[Re: redraptor]
#1414158
04/04/13 10:32 PM
04/04/13 10:32 PM
Posts: 15,487 Florida
scratchnfotraction
I could never shoot this guy.
RIP Dutch
Dutch looked like a cute guy. Having a throttle bracket from a cruise control vehicle can help with the hi-rise intake.
yea,he was one of the best.
the cruz control extention clamp is exactly what I used to raise mine with.
[Re: 72d100]
#1414160
04/25/13 01:37 PM
04/25/13 01:37 PM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
i have another qustion. is the mancini kit the same as the bouchillion?
Yes, they just add their own prefix to the BPE part number.
[Re: Hemi_Ram]
#1414165
05/02/13 01:09 AM
05/02/13 01:09 AM
Posts: 3,235 Marion Illinois
72d100
Marion Illinois
Exactly as I am using a spacer too and it is good to go. Glad it worked out for you. I did; however install a longer linkage adjustment piece that allowed me to dial in the up and kickdown shift points.
where did you get the longer adjustment piece?
[Re: 72d100]
#1414166
05/02/13 09:16 AM
05/02/13 09:16 AM
scratchnfotraction
yep,looks like I will be going with that bracket to ditch the hoky cruz control clamp I am using. close but cant get 100% full throttle with it.
where did you get the extention and would you post a pic of it on your carb/intake?
[Re: scratchnfotraction]
#1414167
05/02/13 10:31 AM
05/02/13 10:31 AM
Posts: 1,739 Grand Forks, ND
Hemi_Ram
Grand Forks, ND
I bought it off of EBAY I think the seller's handle was torqueflite patty. I looked on EBAY last night but couldn't find it but I'll look again. I'll run out and take a pix of my setup and post it this AM
Don't know if he is in business anymore but here is his info: Pat Blais Transmissions 12050 15th Ave NE, Seattle, WA 98125
(206) 365-1966
[Re: Hemi_Ram]
#1414173
05/02/13 11:20 AM
05/02/13 11:20 AM
Hemi_Ram
Grand Forks, ND
I used the previous Edelbrock adjuster years ago when I swapped to a taller manifold. They just screw on to end of your adjustment rod then the adjuster screws on to it.
BTW, Summit Racing has both sizes in stock 1/4" and the 5/16" for $7.95
