throttle/kickdown bracket #1414138
04/03/13 04:29 PM
04/03/13 04:29 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
besides needing the edelebrock adapter what linkage do i need for this
Re: throttle/kickdown bracket [Re: 72d100] #1414139
04/03/13 05:51 PM
04/03/13 05:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a better carb
I am truckless..
Re: throttle/kickdown bracket [Re: 72d100] #1414140
04/03/13 06:50 PM
04/03/13 06:50 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Trash all of it and go with the Lokar cable system. Its too easy and gets rid of all of that stuff.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: throttle/kickdown bracket [Re: 72d100] #1414141
04/03/13 07:06 PM
04/03/13 07:06 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Tough crowd. Good thing you're not asking about your dog...they would be telling you to take it out back and shoot it in the head.
Looks like all you need is the stud that bolts onto the carb linkage. I have the same setup on my truck and it runs fine.
Re: throttle/kickdown bracket [Re: RapidusMaximus] #1414142
04/03/13 07:13 PM
04/03/13 07:13 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
I went with the setup from BPE. Not terribly impressed with the installation and it required a fair amount of modifications but it does appear to work (havnt had a chance to test drive the van yet).
Re: throttle/kickdown bracket [Re: Hugh Jorgan] #1414143
04/03/13 08:15 PM
04/03/13 08:15 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
that's what my '87 has, works fine.
1981 Dodge D150 360 auto
Re: throttle/kickdown bracket [Re: basketcase] #1414144
04/03/13 08:28 PM
04/03/13 08:28 PM
Weatherford, Texas
Weatherford, Texas
I have a 2" spacer under my carb and trying to make the throttle and kick down linkage work properly was driving me nuts so I trashed it all and went to the Lokar setup...works great...didn't know how to answer the op's question so I went with the next best thing...
1968 Plymouth GTX
Re: throttle/kickdown bracket [Re: RapidusMaximus] #1414145
04/03/13 09:28 PM
04/03/13 09:28 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
all so confusing, so do i shoot my dog or not lol
Re: throttle/kickdown bracket [Re: 72d100] #1414146
04/03/13 10:08 PM
04/03/13 10:08 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
maybe something like this would work for now? gfrservb
Re: throttle/kickdown bracket [Re: 72d100] #1414147
04/03/13 10:19 PM
04/03/13 10:19 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
This works great
Takes out all the guess work & doesn't rely on hoping that you drilled the hole in the arm in the right place for the Lokar to work correctly
Uses parts that you can buy at Dodge or a parts store if the cable breaks
Re: throttle/kickdown bracket [Re: BulletBob] #1414148
04/03/13 11:28 PM
04/03/13 11:28 PM
Springfield, Ohio
shortbed88 Offline
shortbed88  Offline
Springfield, Ohio
not to hijack this thread but....what type of replacement cable does that factory setup use? I have one for a Dodge van and the thing is about 6 feet long. I need to get this figured out so I can install my a518.
1988 Dodge D100 Short bed
Re: throttle/kickdown bracket [Re: shortbed88] #1414149
04/04/13 12:59 AM
04/04/13 12:59 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I would take the factory linkage over the crappy Lokar any day!
I have a Lokar cable in my swap meet bucket I took off my Ramcharger. Not able to locate a factory linkage I went with the BPE throttle plate and factory type cable for the 518 trans swap.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: throttle/kickdown bracket [Re: Hugh Jorgan] #1414150
04/04/13 09:25 AM
04/04/13 09:25 AM
scratchnfotraction Offline
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414151
04/04/13 09:27 AM
04/04/13 09:27 AM
here it is on a tall rpm intake. I did riase the throttle cable clamp so the cable was level with the stud since this pic.(and they said stock linkage wont work on the RPM intake...)
stock 78-440 truck 3-piece linkage
just swaped a 3-piece set up over to the 85 318/727 replacing the 1 piece set up. it is off a mid 80s SB 4-v dippy. much more adjustability with the 3 piece.
if you need the tall intake bracket for the B-engine,AREngineering has them.
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414152
04/04/13 09:35 AM
04/04/13 09:35 AM
I could never shoot this guy.
RIP Dutch
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414153
04/04/13 12:18 PM
04/04/13 12:18 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Check out AR Engineering, one of the sponsors for Moparts. Looks like they have nice stuff, and many options.
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414154
04/04/13 01:28 PM
04/04/13 01:28 PM
Marion Illinois
72d100 Offline OP
72d100  Offline OP
Marion Illinois
scratch it looks like we have the same setup, it your throttle cable goig at an angle to the carb. mine might as well be in the back of the carb
Re: throttle/kickdown bracket [Re: scratchnfotraction] #1414155
04/04/13 08:16 PM
04/04/13 08:16 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
RIP Dutch
Dutch looked like a cute guy. Having a throttle bracket from a cruise control vehicle can help with the hi-rise intake.
Re: throttle/kickdown bracket [Re: redraptor] #1414156
04/04/13 09:36 PM
04/04/13 09:36 PM
Indianapolis
Waveraider Offline
Waveraider  Offline
Indianapolis
I have the Bouchillon cable kit and it works great! Took maybe a little more than an hour to install without any help. Looked at the Lokar, but spent the extra money.
Re: throttle/kickdown bracket [Re: shortbed88] #1414157
04/04/13 09:58 PM
04/04/13 09:58 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
91 Dodge van is what I used when I built my 1st one from scratch
The Bouchillion kit uses the same cable it looks like
I compared them when I got my 1st Bouchillion
