changing valve springs on engine #1413775
04/02/13 05:43 PM
04/02/13 05:43 PM
Carson City, NV
babarracuda Offline OP
Carson City, NV
How thick and how much rope is needed? Do you just shove it in the spark plug hole crank up the piston (by Hand) until the piston is up as far a moderate turning allows?
Re: changing valve springs on engine [Re: babarracuda] #1413776
04/02/13 06:26 PM
04/02/13 06:26 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
The thickest rope you can get through the plug hole would be best. 10mm here in Europe, 3/8" would be your best bet.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: changing valve springs on engine [Re: babarracuda] #1413777
04/02/13 06:38 PM
04/02/13 06:38 PM
2 ft of 3/8" white nylon rope from your hardware store. Just move the crank CCW aways down from TDC then feed the rope in leaving just a pigtail out then hand turn the crank CW till it locks. Keep the rope in a plastic grocery bag to keep it clean for the next time.
Re: changing valve springs on engine [Re: RapidRobert] #1413778
04/03/13 09:50 AM
04/03/13 09:50 AM
Carson City, NV
Carson City, NV
Thanks guys! I have built many engines but never changed springs on the engine. The smart man doesn't know everything, he just knows who to ask.
Re: changing valve springs on engine [Re: babarracuda] #1413779
04/03/13 12:23 PM
04/03/13 12:23 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
You'd better hope the rope doesn't get all tangled up once inside the cylinder. You'll end up pulling the head if it does.
Just use air. As long as your valves are sealing properly you won't need to worry about one dropping.
Besides, you won't be introducing fibers or other junk into the cylinders with air like you do with the rope trick. That rope will be clean only on the first cylinder. After that, it's dirty.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: changing valve springs on engine [Re: 340727dart] #1413780
04/03/13 07:24 PM
04/03/13 07:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This tool works great. It lets you use both hands when taking the keepers out and changing the springs or seals. I bought it from Mancini. Ron
Re: changing valve springs on engine [Re: babarracuda] #1413781
04/03/13 07:26 PM
04/03/13 07:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
That is so true. No one can remember everything but knowing where to find the info is important ! Ron
Re: changing valve springs on engine [Re: 383man] #1413782
04/03/13 07:45 PM
04/03/13 07:45 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Just changed a set on a 426RB with eddy heads. With the piston at TDC still had enough room to get the keepers out with the valve pushed down. I used the pro form tool that Mancini has. Would have been easier with the tool that Ron has.
Re: changing valve springs on engine [Re: Todd] #1413783
04/03/13 07:49 PM
04/03/13 07:49 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
x 99 ..... uNless you have some HD triple springs .... use LOTS of air-pressure instead of that rope.
Re: changing valve springs on engine [Re: dOc …] #1413784
04/03/13 08:46 PM
04/03/13 08:46 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ive always used rope. Nothing wrong with it, just takes some finessing, depending on piston head type.
Used air a couple weeks ago. I'll never use rope again!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: changing valve springs on engine [Re: Von] #1413785
04/03/13 10:19 PM
04/03/13 10:19 PM
air is faster & time is money
Re: changing valve springs on engine [Re: Todd] #1413786
04/04/13 01:28 AM
04/04/13 01:28 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
X2, no need to screw with air or rope.
Re: changing valve springs on engine [Re: 383man] #1413787
04/04/13 02:22 AM
04/04/13 02:22 AM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
That Mancini tool looks SLICK
Re: changing valve springs on engine [Re: dOc …] #1413788
04/04/13 03:04 AM
04/04/13 03:04 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Ted...you can borrow the tool i have if you want..
As long as those heads have bolt holes in the end for accessories ..then it will work...has worked on standard heads...eddy heads..and w2 heads..
It is an old Ed Hamburger tool from the 80s...slightly modified ...
Tony
70 AARCuda Vitamin C
Re: changing valve springs on engine [Re: 70AARcuda] #1413789
04/04/13 11:22 AM
04/04/13 11:22 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Ron, is that tool using the pushrod to compress the spring?
Also, where'd you get those rocker shaft studs? Did they come as a kit or did you have to do some work getting ones that worked?
Re: changing valve springs on engine [Re: GTX MATT] #1413790
04/04/13 03:45 PM
04/04/13 03:45 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No the tool has this allen screw that you just screw down and it pushes the valve spring down. You just stop when its down far enough and it stays there while you use both hands to work on removing the spring. Works real nice. The studs are the studs that came with the Hughes rocker shaft hold downs and hardware kit I got from Hughes. Ron
Re: changing valve springs on engine [Re: 383man] #1413791
04/04/13 11:46 PM
04/04/13 11:46 PM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
That Tool is no longer available.
Also if you use rope I suggest using Ski rope. Easier to work with. Easier to clean also. Todd at Marsh performance gave me that Tip.
Re: changing valve springs on engine [Re: MAVERICKSHEMI] #1413792
04/04/13 11:53 PM
04/04/13 11:53 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I bought a Hemi version of this tool a couple years ago....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: changing valve springs on engine [Re: HemiRick] #1413793
04/04/13 11:58 PM
04/04/13 11:58 PM
NASHVILLE
NASHVILLE
Mancini Says Tool is back on order. Guy who invented the tool is having production problems at the present time.....
I just purchased Troutt's Tool for removing 426 hemi springs with Heads on motor. WORKED GREAT. Customer service is great. Also follow up call. They aim to plz....
Re: changing valve springs on engine [Re: MAVERICKSHEMI] #1413794
04/05/13 12:17 AM
04/05/13 12:17 AM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
From who Rick? Mancini Says Back order. Guy who invented the tool is having production problems at the present time.....
From their site ....
$199.95
MREABRBVST
This item is currently out of stock
.... now for 200 beans .... I don't know about that ...
