swapping conv. weights??? #1413160
04/01/13 04:24 PM
04/01/13 04:24 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
Have a turbo action conv. I want to put in a 360ci I'm building for my wife. the T&A conv. is balanced for a cast 340ci. do you guys see any problem knocking off the weights and tacking on the 360'S original conv. weights as close to there position on the 340 conv???? . hope I explained what I want to try right. will be low R.P.M 6,500 or so .
Thanks for any help, Jim
Re: swapping conv. weights??? [Re: jp15] #1413161
04/02/13 08:40 AM
04/02/13 08:40 AM
NC USA
U
ultimatelenny Offline
U
NC USA
Hi, as long as they are located in the same location as the existing 360 converter, you should not have a problem.
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: swapping conv. weights??? [Re: ultimatelenny] #1413162
04/02/13 10:16 AM
04/02/13 10:16 AM
canada
jp15 Offline OP
jp15  Offline OP
canada
Thanks Lenny, just in the process of tacking in place now .
Jim.
