Dave just finished an engine for my friend for his 1970 Road Runner convertible 440 six barrel. 440 .040 over, box stock edelbrock heads. 11:1 compression, 4.15" crank. Uses stock six barrel holley carbs, no port work, no exotic camshaft. Flat tappet hydraulic cam, runs unported iron Hp exhaust manifolds. Sounds pretty tame.
Engine installed back in car and ran on chassis dyno at Jakes auto. Car made 420 HP at the wheels and almost 500 foot pounds of torque. This is with the stock orange box, stock MP distributor..etc. We are going to swap to a revnator box and a hotter coil. Should see 430+ Hp at the wheels. Not bad for a mild build! Thanks a lot Dave!
