Big block power brake booster question.
#1412579
03/31/13 11:14 PM
03/31/13 11:14 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I know I need the smaller diameter booster. If I order one for a 78 with a 440, it will bolt on, right? Just making sure. I have power brakes now on the 84. Thanks in advance!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Big block power brake booster question.
[Re: 76dodgeboy]
#1412582
04/01/13 12:54 AM
04/01/13 12:54 AM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Thanks! Mine has the big diameter booster. Is a slant six short box.
[Re: 76dodgeboy]
#1412584
04/01/13 11:49 AM
04/01/13 11:49 AM
Posts: 15,487 Florida
scratchnfotraction
Just order a 3/4 ton one for your year truck. I've yet to see a 3/4ton with a big booster.
this way the brake pedel hooks up with the clip style brake rod.
the 78 booster will have the shoulder bolt hooking to the pedel.
you can also go to manual brakes for clearance at the VC on the 440,in case you want tall fabricated VC.
here is mine.
