Page 2 of 3 1 2 3
Re: Race car trailer tires [Re: Bigbeep] #1411792
04/01/13 03:42 AM
04/01/13 03:42 AM
Washington
skrews Offline
skrews  Offline
Washington
I was in the tire biz for a while and can say for certain that all trailer tires have way too many failure issues. Started putting high quality high load range truck tires on my trailers and my friends and family's trailers. End of problems. 16" trailer tires did seem to do better than the 15" and 14" stuff. As said before running max pressure will keep the tires happy.
Re: Race car trailer tires [Re: skrews] #1411793
04/01/13 10:28 AM
04/01/13 10:28 AM
Az
Crizila Offline
Crizila  Offline
Az
Make sure your trailer sits level to the ground with a minimum of 10% of the load on the tongue. Load level / anti sway bars is also a good addition to your tow package. If you do have a blow out, everything stays nice and straight.
Fastest 300
Re: Race car trailer tires [Re: skrews] #1411794
04/01/13 10:31 AM
04/01/13 10:31 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Got a brand name for these tires? How much does the 16 inch change height over 15 inch?
Re: Race car trailer tires [Re: cudaman1969] #1411795
04/01/13 11:23 AM
04/01/13 11:23 AM
SD
SG5438 Offline
SG5438  Offline
SD
My 28 ft Vintage had 225x15 Goodyear Marathon's.
For the 4 years they were on it I only had 1
that bulged. I always kept them covered, at
70 psi and rotated them every spring.
I now have BFG Commercial A/S TA's in 225x16.
They only added 1/2in in height. I found a set
of 5 16in 5th wheel Alum wheels on craigslist
for $100. Best thing I did for the trailer, It
tows so much better. No wishy washy sway on the
ruts and bumps of the hi-way, course the hitch
must set up correctly.
I had 40ft 3 axle with 225x15 marathons before
and as long as I kept the pressure at 70, covered
and rotated, I never had had a blowout in 8
years. I did have 3 bulges tho.
Sorry this is long but I firmly believe that
checking the lugs & psi before every tow,
covering when not in use and rotating every
year is a must do.
Rick
2015 3500 Mega Cab Cummins
1970 Plymouth GTX - 7.99 @ 170 @ Bandimere
Re: Race car trailer tires [Re: SG5438] #1411796
04/01/13 02:50 PM
04/01/13 02:50 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I use Mastertrack trailer tires made by Cooper in the USA! Here is where I get them from:
http://www.trailerrvparts.com/
JB Rhinehart, Realist
A-Body's RULE!
Re: Race car trailer tires [Re: Rhinodart] #1411797
04/01/13 05:12 PM
04/01/13 05:12 PM
Az
Crizila Offline
Crizila  Offline
Az
Tires hell, how's your tie-down straps!!!
Fastest 300
Re: Race car trailer tires [Re: Crizila] #1411798
04/01/13 05:25 PM
04/01/13 05:25 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Sounds like a story in the making.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Race car trailer tires [Re: pittsburghracer] #1411799
04/02/13 06:38 AM
04/02/13 06:38 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Hercules are also made by Cooper. That's what I'm going with.
Re: Race car trailer tires [Re: Leigh] #1411800
04/02/13 08:27 AM
04/02/13 08:27 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those are china tires and I have had terrible luck with them on big trucks. No way I would ever buy anymore of them.
Re: Race car trailer tires [Re: Challenger 1] #1411801
04/02/13 12:59 PM
04/02/13 12:59 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
What ever happened to the Maxiss tire recommendation? for trailers
Re: Race car trailer tires [Re: Crizila] #1411802
04/02/13 02:08 PM
04/02/13 02:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Gotta let Rhinodart tell it if he wants to. I will say that my wife ended up with a brand new grill for her 79 300 when it was all said and done.
Fastest 300
Re: Race car trailer tires [Re: Crizila] #1411803
04/02/13 10:30 PM
04/02/13 10:30 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I think we need a sticky, that lists the Country of Origin. It would be nice to know. Links only, nothing else.
Re: Race car trailer tires [Re: Leigh] #1411804
04/02/13 10:43 PM
04/02/13 10:43 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
http://www.maxxis.com/About-Maxxis.aspx
Here's an oft recommended tire. Sounds like an Aisian tire to me. Make it #1 on my sticky request.
Re: Race car trailer tires [Re: Chris'sBarracuda] #1411805
04/02/13 10:45 PM
04/02/13 10:45 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Chris, what is the sidewall mfg code on them? Do they say made in USA? Thanks!
Re: Race car trailer tires [Re: Leigh] #1411806
04/02/13 11:02 PM
04/02/13 11:02 PM
SC
Greg Offline
Greg  Offline
SC
Has anyone had any luck with Towmaster Tires? I had to pick up a tire in KY last year due to a flat and that is what the tire company sold. The company is Greenball corporation and can be found at www.greenball.com. The size was ST225/75/15 10 ply tire. I need to buy some new tires this spring and was wondering if I should give them a chance or go with the Goodyear marathons?
Re: Race car trailer tires [Re: cudaman1969] #1411807
04/02/13 11:05 PM
04/02/13 11:05 PM
Washington
skrews Offline
skrews  Offline
Washington
BFGoodrich or Michelin. I was replacing ST225/75/15 with LT235/75R/15C that had a max inflation pressure of 50 p.s.i. When swapping out 15 inch tires such as a ST225/75/15, I'd use LT225/75R/16E. These will be 1 inch taller.
http://www.tirerack.com/tires/tires.jsp?...um=275R6COMMTAE
Re: Race car trailer tires [Re: Greg] #1411808
04/02/13 11:54 PM
04/02/13 11:54 PM
PA.
"Little"John
"Little"John
PA.
My Towmasters lasted about 3 years before boom, boom boom. 3 blowouts in 2 weeks. Less than 5000 miles on them.
Over 90% of my towing is local as its about 40 miles to PRP. Throw in a trip or 2 out to Norwalk, Ohio late in the year (200 miles each way).
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Race car trailer tires [Re: Leigh] #1411809
04/03/13 12:03 AM
04/03/13 12:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
I'll have to check and get back to you..
Trailer is at my yard..
I bought them here.. Mesa Store..
http://www.robertstire.com/locations.htm
Chris..
Re: Race car trailer tires [Re: Chris'sBarracuda] #1411810
04/03/13 01:25 AM
04/03/13 01:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I just bought the cheapest 10 plys I could find through work. made in china, I'm sure they'll fail, but so has everything else I've put on it. I should try the 16" wheel route. Living in the desert if you get three years from a trailer tire you're lucky!
Re: Race car trailer tires [Re: J_BODY] #1411811
04/03/13 07:22 AM
04/03/13 07:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Well I bought my Carlisle's . We'll see how they work. Clearly states "Made in China"on the sidewall. Discount tire offers a $13/tire road hazard warrantee which I purchased. I'll keep everyone updated. The trailer is a 32 foot enclosed tri-axle. Tires are 225 75/15 load D. I did notice the Goodyear's only seemed to be cracked on the outer corners of the tread,sun?
Doug
Page 2 of 3 1 2 3
