Re: Race car trailer tires
[Re: skrews]
#1411793
04/01/13 10:28 AM
04/01/13 10:28 AM
Posts: 7,506 Az
Crizila
Az
Make sure your trailer sits level to the ground with a minimum of 10% of the load on the tongue. Load level / anti sway bars is also a good addition to your tow package. If you do have a blow out, everything stays nice and straight.
Fastest 300
[Re: skrews]
#1411794
04/01/13 10:31 AM
04/01/13 10:31 AM
Posts: 8,350 fredericksburg,va
cudaman1969
fredericksburg,va
I was in the tire biz for a while and can say for certain that all trailer tires have way too many failure issues. Started putting high quality high load range truck tires on my trailers and my friends and family's trailers. End of problems. 16" trailer tires did seem to do better than the 15" and 14" stuff. As said before running max pressure will keep the tires happy.
Got a brand name for these tires? How much does the 16 inch change height over 15 inch?
[Re: cudaman1969]
#1411795
04/01/13 11:23 AM
04/01/13 11:23 AM
Posts: 37 SD
SG5438
SD
My 28 ft Vintage had 225x15 Goodyear Marathon's. For the 4 years they were on it I only had 1 that bulged. I always kept them covered, at 70 psi and rotated them every spring.
I now have BFG Commercial A/S TA's in 225x16. They only added 1/2in in height. I found a set of 5 16in 5th wheel Alum wheels on craigslist for $100. Best thing I did for the trailer, It tows so much better. No wishy washy sway on the ruts and bumps of the hi-way, course the hitch must set up correctly.
I had 40ft 3 axle with 225x15 marathons before and as long as I kept the pressure at 70, covered and rotated, I never had had a blowout in 8 years. I did have 3 bulges tho.
Sorry this is long but I firmly believe that checking the lugs & psi before every tow, covering when not in use and rotating every year is a must do.
Rick
2015 3500 Mega Cab Cummins 1970 Plymouth GTX - 7.99 @ 170 @ Bandimere
[Re: SG5438]
#1411796
04/01/13 02:50 PM
04/01/13 02:50 PM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I use Mastertrack trailer tires made by Cooper in the USA! Here is where I get them from: http://www.trailerrvparts.com/
JB Rhinehart, Realist
A-Body's RULE!
[Re: Leigh]
#1411800
04/02/13 08:27 AM
04/02/13 08:27 AM
Challenger 1
Cincinnati, Ohio
Hercules are also made by Cooper. That's what I'm going with.
Those are china tires and I have had terrible luck with them on big trucks. No way I would ever buy anymore of them.
[Re: Leigh]
#1411806
04/02/13 11:02 PM
04/02/13 11:02 PM
Posts: 794 SC
Greg
SC
Has anyone had any luck with Towmaster Tires? I had to pick up a tire in KY last year due to a flat and that is what the tire company sold. The company is Greenball corporation and can be found at www.greenball.com. The size was ST225/75/15 10 ply tire. I need to buy some new tires this spring and was wondering if I should give them a chance or go with the Goodyear marathons?
[Re: cudaman1969]
#1411807
04/02/13 11:05 PM
04/02/13 11:05 PM
Posts: 429 Washington
skrews
Washington
BFGoodrich or Michelin. I was replacing ST225/75/15 with LT235/75R/15C that had a max inflation pressure of 50 p.s.i. When swapping out 15 inch tires such as a ST225/75/15, I'd use LT225/75R/16E. These will be 1 inch taller. http://www.tirerack.com/tires/tires.jsp?...um=275R6COMMTAE
