Re: Engine diaper
[Re: montessa]
#1411742
03/30/13 10:44 PM
03/30/13 10:44 PM
Posts: 9,848 MI, usa
dvw
MI, usa
OK guys, almost time for another year of racing! I want to do a little traveling this year so I am trying to cover all of my bases in regards to chassis certification and SFI equipment. For the most part everything is covered my one issue is an engine diaper. My car has an engine plate with the stock K member. I am running an aluminum rear sump oil pan with the center link passing throught it. The pan also has the duel line Milodon setup in it. Have any of you guys had a diaper made for this setup? I know of Dennis Ridgeway and Champion but, I would like to hear any recommendations and experiances.
I have a Russeleri Diaper. I know these have been bad mouthed here in the past. Is it ballistic material, no. Does it have plastic clips, yes. Does it fit my Charlies pan? I sent a diagram of my pan, it fits near perfect. My feeling is that parts aren't "shot out' during a failure in most instances. If the absorbent contains most of the oil, it's done it's job. Hope I don't need it, but at least I have some protection at a reasonable price. Is it 3/2A-5 material, no. How many of you wear 3/2A-5 pants? Doug
