92 D150 ram air install #1411726
03/30/13 09:13 PM
03/30/13 09:13 PM
new jersey usa
11secdart Offline OP
new jersey usa
I bought a Spectre ram air kit ( air cleaner with two 4 inch snorkel inlets , two 4 inch ducts/hoses and inlets ) for my D150. I ran one duct to the factory intake duct work that exits under the turn signal rather than removing the battery and cutting another hole in the radiator support. On the other side I cut a 4 inch hole in the radiator support next to the radiator to draw cold air from behind the grill. My dilemma is : should I install a screen in front of the inlet? The grill is there to keep big objects out and I don`t drive it in the rain.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 92 D150 ram air install [Re: 11secdart] #1411727
03/31/13 12:19 AM
03/31/13 12:19 AM
N
NITROUSN Offline
NITROUSN  Offline
N
With an air filter I would not worry about it. If you get junk in the filter housing then you could add a screen.
Re: 92 D150 ram air install [Re: NITROUSN] #1411728
03/31/13 01:19 AM
03/31/13 01:19 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id put some screen in front of it just like people do in front of the rads. It keeps the bug guts and debris from cloging the rad or filter..
I am truckless..
Re: 92 D150 ram air install [Re: 11secdart] #1411729
03/31/13 11:22 AM
03/31/13 11:22 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Been thinking of doing the same thing to my '78...could you post a picture of the install? Thanks
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: 92 D150 ram air install [Re: RapidusMaximus] #1411730
03/31/13 12:42 PM
03/31/13 12:42 PM
new jersey usa
new jersey usa
I`m going to finish it this week will post pics then, btw I put a screen in.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
