360 domed pistons hitting spark plug #1411473
03/30/13 04:20 PM
03/30/13 04:20 PM
Fort Collins, Colorado
CoDart Offline OP
CoDart  Offline OP
Im assembling my stock stroke 360 magnum and came upon a "snag". The pistons are hitting the spark plugs, even with the .093" thick head gaskets. The heads are RHS indy heads and the pistons are made for this type head. Pistons are the IC743. Here are some pictures of the setup.
How do I go about this?
Re: 360 domed pistons hitting spark plug [Re: CoDart] #1411474
03/30/13 04:30 PM
03/30/13 04:30 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Looks like you are going to have to grind some spark plug "dimples" in the dome of your pistons and maybe some colder heat range plugs with a shorter electrode and ground strap.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 360 domed pistons hitting spark plug [Re: CoDart] #1411475
03/30/13 04:36 PM
03/30/13 04:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Two choices... shorter/retact electrode ot cut a trench
in the pistons... I like to cut the piston to give
it a easier flame travel
Re: 360 domed pistons hitting spark plug [Re: 71yelladustr] #1411476
03/30/13 04:38 PM
03/30/13 04:38 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: 360 domed pistons hitting spark plug [Re: pittsburghracer] #1411477
03/31/13 08:26 AM
03/31/13 08:26 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If indexing the plug doesn't fix it,bring each piston up TDC,screw the plug in untill it touches and marks the dome.With a diegrinder and sanding roll grind a fire slot into the dome at the same angle as the plug.Make sure that the dome is thick enough and only remove the amont necessary.You can even do this with the pistons in the block if you cover everything and seal it up with duct tape and keep it as clean as possible.
Re: 360 domed pistons hitting spark plug [Re: B G Racing] #1411478
03/31/13 08:39 AM
03/31/13 08:39 AM
ill
dennismopar73 Offline
ill
I agree !!
Hard to believe that the plug is hitting??
Re: 360 domed pistons hitting spark plug [Re: dennismopar73] #1411479
03/31/13 11:22 AM
03/31/13 11:22 AM
CoDart Offline OP
CoDart  Offline OP
What spark plug number would you guys recommend?
Re: 360 domed pistons hitting spark plug [Re: B G Racing] #1411480
03/31/13 12:20 PM
03/31/13 12:20 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
We used to have to do that to the Old TRW-L2295 pistons.It worked so good I think TRW changed the cast to have the groove cut in their pistons.This would be better than trying different plugs to get your clearance as it will give you a few more Horse-Power by the plugs having a better flame travel.
PS When doing this I like to make the V-groove a 1/4"-3/8" wide for better flame travel,just be careful on the dept you cut them.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 360 domed pistons hitting spark plug [Re: MRMOPAR622] #1411481
03/31/13 01:24 PM
03/31/13 01:24 PM
CoDart Offline OP
CoDart  Offline OP
If i cant find the right plugs then ill cut a groove in the pistons. What should the minimum clearance be from spark plug strap to piston?
Re: 360 domed pistons hitting spark plug [Re: CoDart] #1411482
03/31/13 03:16 PM
03/31/13 03:16 PM
I would use .060 and hope Better yet go to a retracted gap spark plug type or even a side gap plug type
