Wil this probe / transducer work for cylinder walls? #1410953
03/29/13 07:02 PM
03/29/13 07:02 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I'm looking into "budget" ultrasonic thickness testers and wondering if this particular probe / transducer would be applicable to measuring cylinder walls:
Probe for Ultrasonic Thickness Gauge:
Measuring Range: 0.75mm-80.0mm(In Steel)
Frequency: 7MHZ
Diameter: 6mm
Description: For thin pipe wall or small curvature pipe wall measurement
Re: Wil this probe / transducer work for cylinder walls? [Re: BradH] #1410954
03/29/13 07:13 PM
03/29/13 07:13 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This would likely be used on the outer surface of the pipe where the curvature would have minimal impact to the readings.
Re: Wil this probe / transducer work for cylinder walls? [Re: Stanton] #1410955
03/29/13 07:18 PM
03/29/13 07:18 PM
BradH Offline OP
BradH  Offline OP
Yeah, the description doesn't indicate if the probe's surface is convex or concave....
Re: Wil this probe / transducer work for cylinder walls? [Re: BradH] #1410956
03/30/13 07:23 AM
03/30/13 07:23 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
You want the smallest you can get,the copulant(grease,vasoline) seals the voids.
Re: Wil this probe / transducer work for cylinder walls? [Re: B G Racing] #1410957
03/30/13 01:03 PM
03/30/13 01:03 PM
BradH Offline OP
BradH  Offline OP
The vendor tells me the probe in question is flat. Is a 6 mm (1/4") flat probe used w/ the couplant acceptable for sonic testing cylinder wall thickness?
Re: Wil this probe / transducer work for cylinder walls? [Re: BradH] #1410958
03/30/13 01:29 PM
03/30/13 01:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you want to use couplant and have a hard time fing it I order mine from Grainger Supply.
http://www.grainger.com/Grainger/wwg/sea...&sst=subset
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Wil this probe / transducer work for cylinder walls? [Re: BradH] #1410959
03/30/13 03:26 PM
03/30/13 03:26 PM
Delray beach, Florida
P
Performance Only Offline
P
Brad, if you look at the face of that probe you'll see the center divide. I bought one like that and lightly radiused both sides on a very fine belt sander to get the convex i needed. I've tested mine on material thicknesses ranging from .100 to .500 and it's always within .001-.002 of what the mic reads. For sonic testing cylinder walls i think that's plenty close enough.
machine shop owner and engine builder
Re: Wil this probe / transducer work for cylinder walls? [Re: Performance Only] #1410960
04/08/13 10:14 AM
04/08/13 10:14 AM
BradH Offline OP
BradH  Offline OP
I bought two, in case I screwed one up. I used 600 & 800 wet-or-dry in a 4.375" tapered ring compressor to gradually apply a radius to the face.
I tested both versions of the probe back to back and found I had to recalibrate the tester when switching. The radiused one provided much more consistent readings in the bores and seems to do the trick.
Re: Wil this probe / transducer work for cylinder walls? [Re: BradH] #1410961
04/08/13 10:22 AM
04/08/13 10:22 AM
PA.
"Little"John
"Little"John
PA.
After watching this video I saved it thinking it would work pretty nice when porting heads but I didn't call yet for a price. To afraid.
http://www.youtube.com/watch?v=ldlA8kN3lZQ
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Wil this probe / transducer work for cylinder walls? [Re: pittsburghracer] #1410962
04/08/13 10:24 AM
04/08/13 10:24 AM
PA.
"Little"John
"Little"John
PA.
Here's the place that offers it in the automotive section.
http://www.ndtsystems.com/Transducers/transducers.html
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Wil this probe / transducer work for cylinder walls? [Re: pittsburghracer] #1410963
04/08/13 04:52 PM
04/08/13 04:52 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Flat won't work on cylinders walls properly. It cant touch the wall. The one Dakota sells for cylinders is 2" radius, so it will do down to 4" bore.
2011 Drag Pak Challenger
