Competition Plus Shifter ID Help!! #141062
10/24/08 08:49 PM
10/24/08 08:49 PM
New York
R/T1968R/T Offline OP
New York
Can you tell what kind of car this shifter cam from? It has the bayonet style mount. Also its value. Thanks
Re: Competition Plus Shifter ID Help!! [Re: R/T1968R/T] #141063
10/24/08 09:15 PM
10/24/08 09:15 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what are the numbers? it could be from a truck or van that used the 833OD...
I am truckless..
Re: Competition Plus Shifter ID Help!! [Re: 340SHORTY] #141064
10/24/08 09:21 PM
10/24/08 09:21 PM
New York
New York
what #s am I looking for? which side of the shifter?
Re: Competition Plus Shifter ID Help!! [Re: R/T1968R/T] #141065
10/25/08 03:27 PM
10/25/08 03:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look for a 4-digit number stamped into the Reverse lever.
Re: Competition Plus Shifter ID Help!! [Re: John_Kunkel] #141066
10/25/08 10:12 PM
10/25/08 10:12 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yowza. That is one funky offset! Definitely not from a Mopar van.
I don't think that's for a Mopar application.
Re: Competition Plus Shifter ID Help!! [Re: In_The_Pink] #141067
10/26/08 04:20 AM
10/26/08 04:20 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
That offset is usually found on shifters for Camaro's or Firebirds and a few other GM products. I haven't seen any Mopar with that set up.
Re: Competition Plus Shifter ID Help!! [Re: tecmopar] #141068
10/26/08 10:03 AM
10/26/08 10:03 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Saganaw 4 speed. Looks just like the one I had in a 73 Camero. wrecked those Saganaw trans in that
Camero about 5 times. Then came a "74 360 3 speed Dart, was a lot more fun, lasted longer and was
just as fast. High school DAZE!!!
Snap your neck, mega G-force launch, is all I want!
Re: Competition Plus Shifter ID Help!! [Re: BDS871Cuda] #141069
10/26/08 09:55 PM
10/26/08 09:55 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
69-73 FORD Mustang, Torino, Ranchero, Boss 302, 351, 429 etc.
The serial number stamped along the front side, rear (outboard side when installed) should have a letter in it identifying it as a factory installed unit in one of the aforementioned model cars; the letter has no other significance other than it was a factory piece.
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
