Bulkhead wiring cleaner. Wire brushes and...? #1410356
03/28/13 01:31 PM
03/28/13 01:31 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Hello again. I'm rewiring the underhood harness on the Charger and I will be cleaning both sides of the firewall bulkhead connector. I need to know what you suggest for cleaning the contact points. I used a wire brush but I have yet to get the copper looking shiny as new. There are no damaged or pitted connectors, but I figured that now is the time to get it as clean as possible.
Thanks, Greg
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410357
03/28/13 02:21 PM
03/28/13 02:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
soak them in industrial strength toilet bowl cleaner. Though you may not be able to get the good stuff in commiefornia ?
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410358
03/28/13 02:23 PM
03/28/13 02:23 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
A can of 'Lectra-Motive' can be your friend...
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RSNOMO] #1410359
03/28/13 02:40 PM
03/28/13 02:40 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Its a bit pricey, but works great.
You could also use most any electric contact cleaner spray.
I'm not sure about the toilet cleaner, wouldn't that possibly be too corrosive?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: hp383] #1410360
03/28/13 03:10 PM
03/28/13 03:10 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
are you removing the connectors from the bulk head connector ?
It was time consuming but I made myself a good drawing of what went where and removed them from the connector and cleaned them.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: belv2vert66] #1410361
03/28/13 03:58 PM
03/28/13 03:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
White vinegar will also clean the contacts. I soaked my door jamb switches in it and they turned out nice.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: belv2vert66] #1410362
03/28/13 04:17 PM
03/28/13 04:17 PM
X2 but I'd consider going ahead & replacing them. NAPA 725145-female and 725147-male. It ain't bad once you get the hang of R&R ing them & recrimp/solder em & that's such a problem area I'd just as soon do it right & be done with it . I'm sure one of the cleaners mentioned would work well but it'd be a pain to do em where they are located as it not like it's an item you can remove & soak on your bench. . Holler what/how the cleaner you pick works for you.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410363
03/28/13 04:25 PM
03/28/13 04:25 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Thanks, Greg
I have always used this stuff but then again, I spent my high school and college years working in TV repair. Will not tarnish copper or plated stuff and leaves a light coating to prevent further oxidation.
http://www.radioshack.com/product/index.jsp?productId=12784986
I also pack the connectors with CRC Dielectric Grease to keep water out.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410364
03/28/13 04:39 PM
03/28/13 04:39 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have you a better one with home products:
http://www.dodgecharger.com/forum/index.php/topic,70039.0.html
I made it too
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: denfireguy] #1410365
03/28/13 04:48 PM
03/28/13 04:48 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'I also pack the connectors with CRC Dielectric Grease to keep water out.'
Absitively, posilutely...
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RSNOMO] #1410366
03/28/13 05:11 PM
03/28/13 05:11 PM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
Lime Away. No need to remove the connectors. Pour it in,let it soak a while,rinse with water,blow dry,coat with dielectric grease,assemble.
Ron
In sixty-five I was seventeen and running up one-o-one I don't know where I'm running now, I'm just running on Jackson Browne-Running On Empty
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: runinonmt] #1410367
03/28/13 09:18 PM
03/28/13 09:18 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Remove the female connectors and tighten the loops. Clean with a brush and baking soda/water, lime away if that doesn't do it.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: runinonmt] #1410368
03/28/13 09:18 PM
03/28/13 09:18 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Most of the male connectors are getting replaced, so cleaning them is not an issue. I'm going to save the existing wiring to the wipers. My concern was mostly with the firewall mounted female side.
I bought a can of DeOxit spray. THAT stuff is spendy! $16 for an 8 oz can.
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410369
03/28/13 10:17 PM
03/28/13 10:17 PM
My concern was mostly with the firewall mounted female side. I bought a can of DeOxit spray.
Those are the ones I'd replace as they are so hard to clean . Holler how that spray works
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410370
03/28/13 10:25 PM
03/28/13 10:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Key-Rhyst...
That's caviar price...
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RapidRobert] #1410371
03/29/13 01:44 AM
03/29/13 01:44 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
They are hard to clean, but aren't hard to get right. The loops usually need to be tightened...
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Jim_Lusk] #1410372
03/29/13 01:53 AM
03/29/13 01:53 AM
Jim will that make the male ends scrape em down to clean brass when they go together?
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: RapidRobert] #1410373
03/29/13 03:22 AM
03/29/13 03:22 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, to some degree. I did this to my old 67 Barracuda fastback shortly after I bought it and never had another bulkhead related problem. My niece had an 89-ish GM FWD with the 3.3 V6 and it developed a problem with the connector on the ignition module. Same fix...
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Jim_Lusk] #1410374
03/29/13 04:33 AM
03/29/13 04:33 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
Has anyone used RPM (Rust Prevention Magic) to protect the connectors after cleaning them?
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: Bulkhead wiring cleaner. Wire brushes and...? [Re: Kern Dog] #1410375
03/29/13 05:50 AM
03/29/13 05:50 AM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
I replaced all of them on my 69 Roadrunner with the exception of the ammeter contacts which were converted to straight 10 gauge wires through the bulkhead. I crimped and soldered each one. Napa
725145 for the female and 725147 for the male which
are a little more heavy duty than original.
Dielectric grease on reassembly.........
69 Roadrunner 383 stock
