if so, got a wrong device plugged into... yes, seatbelt system is coded with blue wires
However, seatbelt buzzers are long and flat plastic piece, not L shaped pronghs disposition, and they get two blue wires ( traced )
HOWEVER, lights on buzzer could work the same for seatbelts buzzer and shares same flasher prongs disposition
72/73 Charger dash shown, with untouched wiring
![](http://img31.imageshack.us/img31/843/backofdashframe1.jpg)
The pic on OP looks to be touched or modified ( by the way how is taped )
you can see behind the lights on buzzer the turning light flasher which gets black and red. Black being the input from fuse box, and the red going to steering column turning switch
Being the blue wire spliced into the black wire, which sources on RUN or ACC position, it could be very well a source for seatbelt system HOWEVER, these usually sources directly from fuse box, not spliced from flasher input source.
I never have seen yet the seatbelt system sourced from a diff place than straight from fuse box.
There is a blue wire sourcing the seatbelt relay
