amc roller lifters for big Blocks?
#1409738
03/27/13 11:45 AM
03/27/13 11:45 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Anyone ever use the Comp-861 Lifters in there engines? These AMC Lifters have a oil band pressurized oil to the wheel and bearings... Not sure if these will work bu just thinking? Heres a lik to Comps Lifter spec page http://www.compcams.com/Products/CC-%27Endure%20X%27-0.aspx
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: amc roller lifters for big Blocks?
[Re: Bob_Coomer]
#1409740
03/27/13 07:19 PM
03/27/13 07:19 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
I use the Comp AMC solid roller,According to my CRS me thinks it's the 848.Also send oil up the exhaust pushrods.
[Re: hemi-itis]
#1409743
03/28/13 12:17 AM
03/28/13 12:17 AM
Bob_Coomer
Rock Springs
im not oiling through the pushrds...
[Re: Bob_Coomer]
#1409744
03/28/13 02:52 AM
03/28/13 02:52 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
Bob, I'm putting a set of the Comp Cams 848 in a motor right now, no inforamtion yet on oiling issues, still waiting on pushrods. Hopefully UPS will deliver them tomorrow, if so I will post on here after priming the motor and let you know what happens to me I went out today and look for a oiling hole in the cut away band,I don't see any There are two oil holes up on top of the body but thier no where near the lifter oil galley
[Re: Bob_Coomer]
#1409746
03/28/13 12:36 PM
03/28/13 12:36 PM
Posts: 75,072 U.S.S.A.
JohnRR
U.S.S.A.
If you are not going to pushrod oil then why do you want to use them ? Crane ultra pros oil the wheel also ?
[Re: hemi-itis]
#1409751
03/30/13 10:46 AM
03/30/13 10:46 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You can't beat direct feed to the most stressed part of the valve train, the pushrod cup or ball to rocker arm. Or, if you are a bit paranoid, run both like me. Keeps the springs cool,guarantees good pushrod oiling.
[Re: hemi-itis]
#1409752
03/30/13 01:52 PM
03/30/13 01:52 PM
Posts: 9,864 MI, usa
dvw
MI, usa
When I 1st installed the AMC 848 lifters,there was a loss of 15 psi at idle hot.Restrictors in the pushrods eliminated that issue
How did you restrict your pushrods. What size did you start and end with? Doug
