Alter K Coil Rates real world feedback #1409339
03/26/13 02:11 PM
03/26/13 02:11 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
So I'm getting closer to getting my Alter K road ready. No drag use, strictly street and track day car b body RB. I got 550lb coils and a 1+'? sway bar. Although there are likely many more Alter K users over in the drag forum, not sure their experience correlates to my use.
Their are only 2 ALter K listed in our handling registry, so what rates have you used and how did they perform, including sway bar?
Re: Alter K Coil Rates real world feedback [Re: jcc] #1409340
03/26/13 02:22 PM
03/26/13 02:22 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Subscribed
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Alter K Coil Rates real world feedback [Re: jrlegacy23] #1409341
03/26/13 02:40 PM
03/26/13 02:40 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
damn i forget what i have on mine.. i'd have to go out and check. i have a small block dart so it probably wouldn't help ya much anyway.
what does bill recommend?
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Alter K Coil Rates real world feedback [Re: jcc] #1409342
03/26/13 07:23 PM
03/26/13 07:23 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
What's the motion ratio on the AlterK? Knowing that, we can calculate wheel rates to be compared against known t-bars rates and back into comparable coil rates.
Re: Alter K Coil Rates real world feedback [Re: TC@HP2] #1409343
03/26/13 08:40 PM
03/26/13 08:40 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I could contact Bill tomorrow, or if we knew distance of LCA pivot to wheel centerline?, and distance from LCA pivot point to coilover attachment point on LCA, and we knew or guessed coilover inclination, we would have a number/factor to compare my 550lb coils with a typical TB set-up, for a relative starting point?
When these coils were obtained, years back, they were mutually agreed upon by Bill, along with brakes, etc but a lot has progressed since when .96" TB's were worried about being "harsh".
Re: Alter K Coil Rates real world feedback [Re: jcc] #1409344
03/27/13 10:58 AM
03/27/13 10:58 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Exactly. Its high school level geometry at that point. Once we know what the applied wheel rates are, we can compare apples to apples.
For simplicity, a lot of wheel ratings are calculated at the ball joint rather than the wheel centerline. Obviously wheel offset impacts that actual applied rate the tire sees and the more accurate you calculate this distance, the more accurate your results. I just wouldn't want other potential AlterK users to follow along and end up with different results because they chose a different wheel than you have and then wonder why things aren't the same.
Re: Alter K Coil Rates real world feedback [Re: TC@HP2] #1409345
03/27/13 11:06 PM
03/27/13 11:06 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Re: Alter K Coil Rates real world feedback [Re: Devil] #1409346
03/28/13 11:04 AM
03/28/13 11:04 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thanks Devil. We all know you are an ardent E-burg supportor and think the AlterK is one step above scrap metal. Unless you have relevent info on motion ratios, there is nothing to see here...
Re: Alter K Coil Rates real world feedback [Re: jcc] #1409347
03/28/13 12:01 PM
03/28/13 12:01 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Im interested to see how this works out for you. When I bought my system, I spent quite a bit of time talking to Bill. He typically recommended the 450lb in front, but since i had the viper motor and intended to autocross, we stepped up to 550lb (btw sway bar is 1.25").
Bill did say he would do a free swap with me once if I wanted a different spring rate.
On the car, it feels quite stiff - but car isnt fully assembled or driveable (mock up), so I cant give you a real world testimony for a while.
My car is lowered, and I have found that springs supplied are too short under full rebound - so I'll need to adjust accordingly down the road. Just something to consider that if you intend to run a lot lower...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
Re: Alter K Coil Rates real world feedback [Re: G_T] #1409348
03/28/13 03:09 PM
03/28/13 03:09 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Yes we have many things in common on our builds, yours sounds really nice and well balanced.
Recently received RMS email motion ratio is wheel weight x 1.3 equals spring load. Measuring my Alter k mock up with a tape measure with my selected wheels, I get 1.6 x wheel equals spring load or 343lbs/in compared to a TB. FWIW my swaybar is not 1.25", as it was not offered at the time, and yes Bill has made very accommodating offers on changing springs rates
These springs are 2.5"ID x 9" and offered in numerous 25/50lb rates by a number of manufacturers.
As best as I can tell, RMS measures from the ball joint with their ratio, and mine is from the wheel centerline I have chosen.
Re: Alter K Coil Rates real world feedback [Re: jcc] #1409349
03/29/13 12:57 PM
03/29/13 12:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
So there you go, about equivlent to a 1.19 or 1.20 t-bar with your current set up.
