Muffler Choice Question #1409257
03/26/13 01:03 PM
03/26/13 01:03 PM
Anonymous OP
Anonymous OP
'70 Challenger, 440. TTI 2.5" system with X-pipe. Currently have Dynomax Super Turbos on the car. My understanding is they are more restrictive than a straight through muffler like the Ultraflo or Magnaflow. In addition, I have the typical drone in the 1500-2000 rpm range.
Would like a quieter sound so I can hear the radio, have a conversation, and not have to wear earplugs. However, want the badass sound when I stomp on it.
So, what are my options to have a straight through system, no drone, able to have a conversation while cruising, and nice sound when I stomp on it. Don't want the Dynomax VT's because I don't trust moving parts in a muffler. Thanks.
Re: Muffler Choice Question [Re: ] #1409258
03/26/13 01:08 PM
03/26/13 01:08 PM
dogdays Offline
dogdays  Offline
Wrong.....The Dynomax Super Turbos are some of the least restrictive mufflers, at least in the 2.5 or 3" varieties. Add a resonator farther back to cut the drone.
R.
Re: Muffler Choice Question [Re: dogdays] #1409259
03/26/13 01:51 PM
03/26/13 01:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
R.
the mufflers you want to switch to are straight thru design , it's only going to get louder.
Re: Muffler Choice Question [Re: ] #1409260
03/26/13 02:09 PM
03/26/13 02:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Are you running stock manifolds with TTI pipes?
Re: Muffler Choice Question [Re: Challenger 1] #1409261
03/26/13 02:36 PM
03/26/13 02:36 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
dynomax VT sounds like exactly what you want....straight through, aggressive when on the throttle, drone free at cruise....
or how about just putting some quiet, restrictive mufflers on, then electric cutouts in front of them hooked up to a normally closed vacuum switch? vacuum applied (cruise) and you have no power going to them, and exhaust flows through the mufflers, stomp on it, vaccuum drops to 0, you get electrical current which opens the cutouts?
2017 Grand Cherokee Overland
Re: Muffler Choice Question [Re: ] #1409262
03/26/13 02:57 PM
03/26/13 02:57 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Ihave the Dynomax turbos on my stroker without any drone issues. I believe that my B body has more pipe after the muffler than an E body though.
This is the land of the free because of the brave
Re: Muffler Choice Question [Re: rbstroker] #1409263
03/26/13 03:03 PM
03/26/13 03:03 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have been running the super turbos for 13 years on my SB and BB since 2005 with no drone. I run headers and was wondering if the drone was more likely with stock exhaust manifolds??
Re: Muffler Choice Question [Re: Challenger 1] #1409264
03/26/13 03:08 PM
03/26/13 03:08 PM
Anonymous OP
Anonymous OP
yes
Re: Muffler Choice Question [Re: patrick] #1409265
03/26/13 03:12 PM
03/26/13 03:12 PM
Anonymous OP
Anonymous OP
I know, but I worry about that little flap making noise, getting stuck or the spring breaking.
Re: Muffler Choice Question [Re: JohnRR] #1409266
03/26/13 03:14 PM
03/26/13 03:14 PM
Anonymous OP
Anonymous OP
R.
What about a straight through muffler with a resonator farther back?
Re: Muffler Choice Question [Re: ] #1409267
03/26/13 03:43 PM
03/26/13 03:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Do your pipes go all the way to the back of the car ? Mine do and I run a 3" X-pipe system with the Ultra-Flows and its not to bad. I listen to the radio and talk to anyone in the pass seat. Yes it is a little noisey but not bad to me for what it is. But if your tail pipes are not to the rear of the car it can be anoying if the pipes come out on the side of the car. Ron
Re: Muffler Choice Question [Re: 383man] #1409268
03/26/13 04:26 PM
03/26/13 04:26 PM
Anonymous OP
Anonymous OP
Yes, they go all the way to the back and have the stock type tips.
Re: Muffler Choice Question [Re: ] #1409269
03/26/13 04:31 PM
03/26/13 04:31 PM
P
Paul_Fancsali Offline
P
I the box tips make more noise I went to downturn tailpipes and its definitly quieter Plus the stock ones are barely 1.58 inch where they enter the tailpipe
Re: Muffler Choice Question [Re: Paul_Fancsali] #1409270
03/26/13 04:42 PM
03/26/13 04:42 PM
Anonymous OP
Anonymous OP
Mine are the TTI stock appearing tips and are the same size as the rest of the system. They'll be staying on.
Re: Muffler Choice Question [Re: ] #1409271
03/26/13 05:14 PM
03/26/13 05:14 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
Super Turbos are MORE restrictive than Ultraflos. Depends on your HP of your engine. May not be enough to notice in the seat of the pants. The 2.5" Turbos neck down inside the case. 3"er's don't I believe.
Re: Muffler Choice Question [Re: ] #1409272
03/26/13 06:11 PM
03/26/13 06:11 PM
JohnRR Offline
JohnRR  Offline
R.
Hemi E bodies had a resonator at the rear of the tailpipe so you could surely go that route with a straight thru canister type muffler or a factory resonator ?
Re: Muffler Choice Question [Re: ] #1409273
03/26/13 06:29 PM
03/26/13 06:29 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
An insulated trunk divider helps...
Re: Muffler Choice Question [Re: RSNOMO] #1409274
03/26/13 06:51 PM
03/26/13 06:51 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
along with a sound deadening matt on the floorpan underneathe the rear seat. Believe it or not, certain mufflers will vibrate the floorpan to cause a droaning sound at certain speeds. I did a full floorpan on a '69 runner with Flow(rust)master 40 series 2 chamber and it quieted interior noise alot! As for muffler choice with good flow and sound, I'm stuck on Borlas.
Re: Muffler Choice Question [Re: ] #1409275
03/26/13 06:57 PM
03/26/13 06:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dont blame you as I like the looks of the stock tips. They would stay on if was mine also. Ron
Re: Muffler Choice Question [Re: 383man] #1409276
03/26/13 09:13 PM
03/26/13 09:13 PM
Central NC
gch Offline
gch  Offline
Central NC
A resonator in the tailpipe will work fine.I would not be afraid to run the VT muffler.The flap and spring are stainless steel and I haven't heard of one breaking.
I just switched to the Borla Pro XS on my mustang with long tube headers,x-pipe,and no cats and it is pleasant to drive again.
I have had hemi(longer case) super turbos on my Polara for years.Love them but they did drone with tips out the back.Switched to factory style turn down tips just below the bumper and it is damn near quiet at cruise.I hear the engine more.
