What Brand Alternator? #1409221
03/26/13 11:59 AM
03/26/13 11:59 AM
Dreaming of Idaho
U
unlucky68 Offline OP
U
Dreaming of Idaho
I believe the bearing on my alternator is shot and I am wondering if I should buy from a big box store or if I should buy one from Summit Racing like a Tuff Stuff or Powermaster? This is for a cruiser 318 car and pretty basic. I was thinking like NAPA but, I've heard people have problems with them crapping out every 2 or 3 months. FWI, I already have the amp gauge converted to a voltmeter by Redline. I was thinking something about 60-75 amps should be enough for my purposes. I also see RockAuto has like AC Delco and the likes. Just wondering if one brand is better than the other.
Re: What Brand Alternator? [Re: unlucky68] #1409222
03/26/13 12:24 PM
03/26/13 12:24 PM
I believe the bearing on my alternator is shot This is for a cruiser 318 car and pretty basic.
Hows it acting? sometimes an electrical fault can cause a high pitched squeal that can be mistaken for a bad bearing. If that's what's going on pull a field wire & if it gets quiet than it's an electrical issue. If not you might open it up & check/grease the end bearings. On a new one I'd just get a 78 amp unit for an 85 M body I believe. Not sure what all you've done to your wiring but I would clean ALL connections/terminals & do Nacho's 2 wire bulkhead parallel bypass (simple/easy/effective)
Re: What Brand Alternator? [Re: RapidRobert] #1409223
03/26/13 12:43 PM
03/26/13 12:43 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
I used a 78 amp reman unit from an '87 Diplomat from Autozone for warranty and ease of exchange if there is a problem.No issues as yet on my '66 Chrysler after some wiring upgrades and amp gauge bypass.I'm not really familiar with the aftermarket alts.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: What Brand Alternator? [Re: GrnMagic77] #1409224
03/26/13 01:18 PM
03/26/13 01:18 PM
dogdays Offline
dogdays  Offline
It's the luck of the draw. One NAPA alternator lasted 5000 miles then caught fire. The replacement from NAPA is still running years later.
I say you do what the others are saying and get the mid-80s alternator from a store that promises a lifetime warranty and live with it. There's no reason to slag NAPA, I bought a rebuilt from Advance Auto that was bad right out of the box. Of course they replaced it and that one is doing fine as well.
Name a store and someone on the board will have a horror story. I am convinced that this is the direct result of us consumers shopping for price above everything else. We run the good guys and suppliers out of business and then b!@#$ about the ones that are cheap enough to live.
If I had my druthers I would take a dead alternator to a local rebuilding shop and they'd fix it. Sadly for us Denverites, that shop is gone and a highrise condo sits in its place.
Progress!
R. (feeling old this morning)
Re: What Brand Alternator? [Re: dogdays] #1409225
03/27/13 07:20 AM
03/27/13 07:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We used remans from Advanced for years at the shop.Used NAPAs also.Never really had any problems and most were on cars that were daily drivers.My 65 I used Summits chrome alt.Its been on for 6 years and no problems.It was under 100 bucks.If I didnt want chrome it would be running a reman.Rocky
Chrysler Firepower
Re: What Brand Alternator? [Re: therocks] #1409226
03/27/13 09:47 AM
03/27/13 09:47 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I'd also use a local reman with a lifetime warranty, for ease of getting a replacement if needed. I got mine from NAPA, it came with this spec sheet. Btw that's alternator RPM not engine RPM in the chart.
Re: What Brand Alternator? [Re: RapidRobert] #1409227
03/28/13 11:09 AM
03/28/13 11:09 AM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
What kind of electrical problem can cause this noise?
I've heard it and had it.
Sounds like a belt/bearing, right?
Re: What Brand Alternator? [Re: Stroker] #1409228
03/28/13 11:18 AM
03/28/13 11:18 AM
What kind of electrical problem can cause this noise? I've heard it and had it.
Well my electronics knowledge is very limited so from a laymans point of view it's a high pitched squeal that sounds like a siren/very uncomfortable as it sounds like it is ready to blow up
