Big block truck vs car bell housing #1408727
03/25/13 05:13 PM
03/25/13 05:13 PM
NJ
70_FJ6_RR Offline OP
NJ
Please school me on big block truck vs car bell housings. My truck is an '82 D150 with a slant 6 and a '68 road runner A833 4 speed 23 spline(yes, it has an adapter ring). I'm looking into a 440 with a 10.5" flywheel and clutch. Can I use a 10.5" big block car bell housing with the slant 6 Z bar, or does it need to be modified?
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408728
03/25/13 08:37 PM
03/25/13 08:37 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The BB bell is bigger in diameter than the /6 bell. You will need to modify it.
I am truckless..
Re: Big block truck vs car bell housing [Re: 340SHORTY] #1408729
03/25/13 09:02 PM
03/25/13 09:02 PM
NJ
NJ
Not to confuse anyone, but, I may put a 440 in the truck, but can I use a 10.5" car bell housing with the slant 6 Z bar? Or does it have to be a small or big block Z bar with the 10.5" bell?
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408730
04/03/13 02:32 PM
04/03/13 02:32 PM
NJ
NJ
Is it possible to use a big block car bell housing in a 440 truck?
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408731
04/03/13 03:43 PM
04/03/13 03:43 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
There's plenty of room for a car bell in a truck...the question is, will the pivot stud for the z-bar be in the right place?
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408732
04/03/13 09:18 PM
04/03/13 09:18 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The z bar for a slant 6 is longer (wider) then a z bar from a small/big block. The diameter of the slant 6 bell is smaller then the bell on a small block, so the distance between the bell and the frame is different between the two.
There have also been changes of the location the z bar attaches to the bell and changes of location to where the z bar attaches to the frame. That change effected the angles and lengths of the arms on the z bar itself as well. Essentially, you need to have the location of the frame pivot stud for the z bar and the pivot stud location on the bell in line with each other so the z bar pivots squarely and evenly. Then you need the z bar to have the correct length so it doesn't bind or fall out. The finally, the arms on the z bar have to be in the correct position to line up with its corresponding end, at the correct angle and be of proper length to release and apply pressure on the throwout arm (which also has to match the bell).
The problem is, most car body lines had z bars and pivot points for specific body/motor/bell arrangements, and those changed at least 2 times for at least A & B body cars that I can think of off hand. I'm just not sure when those changes were made between about 65 and 75. Now you want to add trucks into the equation. Trucks could have been ordered with a whole slew of combinations from hydraulic to mechanical linkage, slant 6 to small block to big block to diesel, from 3 speed, to car 4 speed, OD 4 speed, heavy duty 4 speed, to 5 and 6 speeds.
You have a pile of parts and want us to tell you everything is going to fit? OK, it will all fit, you may have to make some modifications. I suggest you start with the z bar that was attached to the bell you are going to use, and plan on modifying the pivot point and z bar arm length to match your truck on the frame side. Gene
Re: Big block truck vs car bell housing [Re: poorboy] #1408733
04/04/13 01:04 AM
04/04/13 01:04 AM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
you will have to use a car bell with the a-833, the big block truck bell that i have has bolt holes for np-435. you may have to mod/swap ballstud brackets and z bars but thats easy stuff
Re: Big block truck vs car bell housing [Re: Diplomat440] #1408734
04/04/13 01:37 PM
04/04/13 01:37 PM
dogdays Offline
dogdays  Offline
My '64Dog's hydraulic clutch keeps looking better and better!
R.
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408735
04/04/13 11:44 PM
04/04/13 11:44 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
or find this bell and be done with it.
Moparlee
Re: Big block truck vs car bell housing [Re: poorboy] #1408736
04/05/13 04:15 PM
04/05/13 04:15 PM
NJ
NJ
Thanks for all the info! My best bet is to modify the slant 6 Z bar, unless someone knows a close Z bar fit for a 10.5" bb bell in a '82 Ram.
Re: Big block truck vs car bell housing [Re: 70_FJ6_RR] #1408737
04/05/13 06:59 PM
04/05/13 06:59 PM
Lehigh Acres, Florida
rickstershemi Offline
Get in-touch with Brewer's Performance....they can point you in the right direction as well as supply any missing parts you may need....good folks (937) 947-4416
Rickster
Re: Big block truck vs car bell housing [Re: Robbins] #1408738
04/08/13 04:21 PM
04/08/13 04:21 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
THat BB truck bell is a tough one. It has the A833 pattern. Most did not.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Big block truck vs car bell housing [Re: Dan Brewer] #1408739
04/10/13 03:30 PM
04/10/13 03:30 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Ya...........but they are out there. That one site still has the one for sale. That truck Lakewood bell can do the same thing though. If I'm not mistaken.
I had put a car bell in my short bed once cause my truck bell(SB) broke the ball where the clutch fork rides on(80's)130 tooth flywheel bell and the angles were never right with the car bell as far as the clutch fork goes. I'm sure there are ways of getting around it, but I just finally fixed the truck bell and put it back in.
Moparlee
Re: Big block truck vs car bell housing [Re: Robbins] #1408740
04/10/13 05:05 PM
04/10/13 05:05 PM
scratchnfotraction Offline
you can fab up a bracket to hold a slave cyl and use a hydo clutch pedel/MC
IIRC member Commando did that in his C-body for a BB 4 -speed,used cheap over the counter parts.
seemed ez enuff to me and have thought about that same set up on my 88 truck that has the firewall hole for clutch MC already.
I would like to use a lakewood bell myself but the clutch mech linkage is my hold up so far.
