Compression Help??
#1408716
03/25/13 05:00 PM
03/25/13 05:00 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I dont have a calculator any longer, and I checked a couple onlines.. and got 20:1 with one and 7:1 with another LOL... So 4.375 bore 4.15 stroke pistons are large relief B1's with Id say 10-12cc range aluminum rod engine, pistons are .030 in the hole use a gasket in the .032-.035 range with a 4.44-4.5 bore size.. Heads are 53cc Holy cow... yep.... Just ball park Im going to give it the ole gray matter guess and say 13.75-14:1+ I hope Im not leaving something out...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: Compression Help??
[Re: Cheatham]
#1408721
03/25/13 10:50 PM
03/25/13 10:50 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
are the pistons below the deck if so how much? and dont forget the area above the top ring
Says .030 if you read his post
[Re: Mopar-Al]
#1408722
03/26/13 12:30 PM
03/26/13 12:30 PM
Bob_Coomer
Rock Springs
Thanks guys Yep, its a aluminum rod engine, the pistons are .030 in the hole.... try to get this beast running.
