New guy here #1408675
03/25/13 04:23 PM
03/25/13 04:23 PM
St.Pete, FL
lateagain Offline OP
St.Pete, FL
New to the board, not new to Dodge tho. Been driving one on and off since my 90' W150 that I never should have sold...on that note, I joined because I'm back in the family. I picked up an 88 D150 and a 89 Ramcharger as a 4WD donor .
I'm doing some poking around and found one thread on the subject but I'm open to pointers, never done a project like this before.
Quick Q? whats the easiest way to get the rivets out of the frame? So far they're winning. TIA guys
Re: New guy here [Re: lateagain] #1408676
03/25/13 04:39 PM
03/25/13 04:39 PM
scratchnfotraction Offline
HI and Welcome,I am 30 miles north of you in Pasco 85 stepside for daily driver/88-440 truck for weekend cruzer.
I use a 1/4" drill bit to drill into the head of rivit frame deep,then swap to a 1/2 drill bit and drill it out again. then take an airchisel and cave the head in on itself and drive the rivit out.
or drill all 4 rivets/chisel head off and pry bracket off,then whack the rest of rivit out of frame.
smokewrench is the fastest but still need to drive rivits out of frame/pry brackets off.
are you swaping the 4x4 stuff to the 2x truck?
I have always fabed up stuff when converting over a 2x, but mainly for lift reasons.
if you want a cheap 4" lift for the rear the shackle flip is nice for the rear for not adding more blocks to the 3.5 blocks it has in stock form.
you would use a set of front spring hangers from the donor truck on the rear shackle to flip it.
this also lowers a truck like on my 88.
are you swaping out the frame part under the engine as well to remove the coil spring pockets makeing room for the front diff and drive shaft?
going higher could solve/save a lot of work but does not look nice IMO.
Re: New guy here [Re: scratchnfotraction] #1408677
03/25/13 04:51 PM
03/25/13 04:51 PM
St.Pete, FL
St.Pete, FL
Sounds like I have to swap the cross member under the engine, not doing any lift.I'll add that to the list, glad I kept the whole rolling chassis.
Just looking to get her up to normal 4x4 ride height. My daily driver right now is an old H1, my other bad habit. I got the 88 so I'd have a pickup and then the RC fell in my lap and I figured why not...fun project for my son and I.
Re: New guy here [Re: lateagain] #1408678
03/25/13 07:21 PM
03/25/13 07:21 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Yep. Drill & chisel like scratchy says. Welcome to the board!
Re: New guy here [Re: lateagain] #1408679
03/25/13 07:38 PM
03/25/13 07:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Torch
Re: New guy here [Re: lateagain] #1408680
03/25/13 07:40 PM
03/25/13 07:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I also have some 4" Front lift springs Im willing to get rid of
Re: New guy here [Re: 76dodgeboy] #1408681
03/25/13 09:18 PM
03/25/13 09:18 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
WELCOME!!
Re: New guy here [Re: lateagain] #1408682
03/25/13 11:10 PM
03/25/13 11:10 PM
Lehigh Acres, Florida
rickstershemi Offline
Welcome to the madness Matt
Rickster
Re: New guy here [Re: rickstershemi] #1408683
03/26/13 12:20 AM
03/26/13 12:20 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
welcome and post up some pics of your project!
1981 Dodge D150 360 auto
Re: New guy here [Re: basketcase] #1408684
03/26/13 12:57 AM
03/26/13 12:57 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Torch or cut an X on the head with a grinder & knock them out with a chisel & hammer
Re: New guy here [Re: BulletBob] #1408685
03/26/13 10:20 PM
03/26/13 10:20 PM
St.Pete, FL
St.Pete, FL
Not staying like this for long, found out today that the springs have add-a-leafs in them so I am getting some lift out of it over stock height.
Also the front cross member looks to be the same other than the pickup version is "boxed" in and part of the front suspension bolts to it. Still not sure if I need to change it out, I'd rather not since it has the motor mounts and such...
Re: New guy here [Re: lateagain] #1408686
03/27/13 02:15 AM
03/27/13 02:15 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's a axle flip & van LCA's
Re: New guy here [Re: BulletBob] #1408687
03/28/13 07:29 AM
03/28/13 07:29 AM
St.Pete, FL
St.Pete, FL
Anyone know if i can pull the cab/front clip off as one assembly? I'd like to do this so I don't have to lay on my back to drill all the holes in the top of the frame.
Re: New guy here [Re: lateagain] #1408688
03/28/13 11:12 PM
03/28/13 11:12 PM
yes you can if you have a way to slig/lift it/balance it.
on mine I pulled the front clip as a unit then the cab with no doors at the time.
rolled the cab over back down/no glass to sandblast the bottom and under coat.
IIRC if you do not change the crossmember/engine support and get rid of the coil spring pockets the diff/shaft has no room to flex around.
it is a little more work unless you go up with lift to clear stuff.
look it over good on the 4x4 in that araea and you will see they way it is made different.
Re: New guy here [Re: scratchnfotraction] #1408689
03/28/13 11:15 PM
03/28/13 11:15 PM
St.Pete, FL
St.Pete, FL
Thanks, it is hard to get a good look at the pickup with the stance it has right now. I'm going to put it on jack stands this weekend and do some measuring. Still driving rivets out of the frame in the evenings when I have time..
Re: New guy here [Re: scratchnfotraction] #1408690
03/29/13 01:18 AM
03/29/13 01:18 AM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Also for rivets, I've taken a cutoff wheel and made an X in the rivet or even another grind across it, and then taken an airchisel and knocked out each cutout section if that makes sense!
-J
Re: New guy here [Re: lateagain] #1408691
03/29/13 04:05 AM
03/29/13 04:05 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Ramchargers only real diff in chassis is the length. Suspension etc is the same 4x4 to 4x4 and 2x to 2x. Thats why a Cummins bolts rite in
Re: New guy here [Re: 76dodgeboy] #1408692
04/02/13 06:23 PM
04/02/13 06:23 PM
St.Pete, FL
St.Pete, FL
Update, down to the old frame, next week I tear into the pickup...pulling the front clip and the cab to make the new build easier on my torn up neck
