Picked up the new Santhuff's last week... !!!
#1407941
03/24/13 02:46 PM
03/24/13 02:46 PM
Posts: 903 Saskatchewan, Canada
cudabin
Picked up a couple of double adjustable front shocks for the Cuda from M2Performance in Indiana last week. I enjoyed visiting Mike Roth's shop where he has some all out chassis projects on the go... These Santhuff shocks are impressive to view and I can't wait to try them out in May once the snow melts. Cheers, Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Picked up the new Santhuff's last week... !!!
[Re: Dyno1]
#1407945
03/24/13 03:11 PM
03/24/13 03:11 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
1 click at a time is very noticeable unlike other shocks out there. You will love them
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: barracudabob]
#1407949
03/24/13 06:04 PM
03/24/13 06:04 PM
cudabin
Travel is not an issue for me as I already restrict the front end travel to 2.5" in order to control the wheelies... The A body shocks have 3.5" travel, which is multiplied at the wheel from the control arms. Bob, I will install them the 3rd week of April and we can set something up after that. Cheers, Arnie
[Re: MR_P_BODY]
#1407953
03/25/13 12:11 AM
03/25/13 12:11 AM
cudabin
Nope, not cheap... but should help control the wheel stands and my car is very traction sensitive so I need to dial a wheelie. The Strange double adjustable i was running worked better at full tight on both ext and comp, but I wanted more adjustment. They are almost twice the cost of the Strange, so I hope to see a difference in control. The shaft is unreal thick and strong, and Mike Roth said they could be used without travel limiters and topping out will not hurt them. Can't wait to get them set up. I plan to start at 6 clicks from full tight on Compression, and 1 / 1/2 turns out from full tight on extension. Cheers, Arnie
[Re: 72demon416]
#1407956
03/25/13 01:11 PM
03/25/13 01:11 PM
cudabin
Hey Fireguy, what 60 foot times do you run? Are you restricting front travel?? 72 Demon, they are listed at $1,000 per pair, but contact Mike Roth at Mr2Perfomance and ask for the Moparts discount... Cheers, Arnie
