Page 16 of 17 1 2 14 15 16 17
Re: Rampage [Re: mcat4321] #1407919
07/07/13 12:03 PM
07/07/13 12:03 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Good to hear! I also was surprised to see a summit box on my doorstep yesterday...now only if this weather would allow me to get some "testing" done
i am no purist by any means.. but those T/A blocks are very desirable by the guys restoring those cars..
there are lots of non desirable 340/360 blocks for race applications...1 T/A = 3-4 non t/a blocks
strong factory block = desirable race block
I'd save the "non-desirable" hardware for the car show crowd
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Rampage [Re: MR_P_BODY] #1407920
07/07/13 12:16 PM
07/07/13 12:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I admire your work ethic!
Re: Rampage [Re: FastmOp] #1407921
07/07/13 12:33 PM
07/07/13 12:33 PM
MR_P_BODY Offline OP
I dont know about that... if it was good this engine
would have been running fine... I over looked something
but after giving it some thought I think I know where
I went wrong... I will correct it
Re: Rampage [Re: MR_P_BODY] #1407922
07/07/13 03:17 PM
07/07/13 03:17 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Just look at the work you have done in this post. That's why this sport is not for the week.
We all have our bad days. You will get it lined out!
My elCamino is almost the exact same red.
Now it's back to body work for me so I don't feel like an old guy is working harder then me
Re: Rampage [Re: FastmOp] #1407923
07/10/13 03:47 PM
07/10/13 03:47 PM
Minor set back today... as I was going through the
W-2 heads I found a broken valve spring... they ship
on 7/22.... at least I found it.. surprisingly it
was a inner... I checked another set of springs to
see if I could steal the inner... nope... MUCH weaker
inner spring... I might pull a spring from the W-5
just to get it on the road.. its still too wimpy for
what I want but I can get on the road and I can change
them out when they show up.. I'll just have to take
it sorta easy till then
Re: Rampage [Re: MR_P_BODY] #1407924
07/10/13 05:34 PM
07/10/13 05:34 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Mike you realy cant seem to get a break from the bad luck
hope it turns around for you soon!
Re: Rampage [Re: MR_P_BODY] #1407925
07/10/13 05:43 PM
07/10/13 05:43 PM
Just curious.....sounds like you pulled an engine out of your race car and are tearing it down....were even contemplating starting with a different block...........
What was so wrong with the engine in the Rampage that you couldnt fix that just as easy/easier than what you are doing ??
Re: Rampage [Re: 1Fast340] #1407926
07/10/13 05:44 PM
07/10/13 05:44 PM
You got that right... well now I know why it slowed
down the last time this engine ran.. the spring slowly
started winding up on itself... it lost .2 in 2 passes
then I told my driver.. we're done.. somethings wrong..
at least other than the spring nothing was hurt
Re: Rampage [Re: ] #1407927
07/10/13 05:49 PM
07/10/13 05:49 PM
It needs lifter bore bushings... when the oil get hot
it starts dropping pressure.. its right on the edge
of exposing the oil port... with the thicker oil it
covers it up enough
Re: Rampage [Re: MR_P_BODY] #1407928
07/13/13 12:14 AM
07/13/13 12:14 AM
I ran into a first today... I was putting the oil pump
on my 396 SB thats going into the Rampage.. I put the
pump on and the pan... went to roll the crank around
and clunk and the crank stopped... so I pulled the pan
and turned the crank to see the counter weight hits
the oil pump... I had another pump so I put that one
on and it clears by .050 or so.. thats the first time
I ever had the oil pump get in the way... and that
pump was in the 416 engine and cleared fine... I
will look tomorrow to see if the rear main is just
a little shorter... or if its a casting thing on that
pump (but it cleared the 4" crank and the pump that
was in this engine cleared... oh well... it goes along
with the rest of the stuff on this car... it HATES ME
Re: Rampage [Re: MR_P_BODY] #1407929
07/13/13 02:37 AM
07/13/13 02:37 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Your luck is sounding a lot like how mine is normally....
Re: Rampage [Re: MR_P_BODY] #1407930
07/13/13 02:54 AM
07/13/13 02:54 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Quit calling her names.Told you to talk nice.You will get there.Shes just being abit needy.
Re: Rampage [Re: ksj] #1407931
07/13/13 11:03 AM
07/13/13 11:03 AM
tboomer Offline
tboomer  Offline
Mike....Gotta give you an "A" for effort! A lot of guys would have given up by now! You sure are a persistent [Edited by Moparts - Family Friendly Site - Keep it clean]!!
Re: Rampage [Re: tboomer] #1407932
07/13/13 01:15 PM
07/13/13 01:15 PM
LOL... maybe thats my problem... I dont know when
to give up...all thats taken care of now but I'm
fixing some other small things on this engine that
I should have 8 years ago.. the edges of the intake
are a little high and the valve cove JUST sealed before
so I cut that down... I'll clean up the shop tomorrow
then I should be ready to put it in on Monday...
plus I want to cut a access panel in the fender well
so I can get the starter out easier
Re: Rampage [Re: MR_P_BODY] #1407933
07/13/13 01:29 PM
07/13/13 01:29 PM
tboomer Offline
tboomer  Offline
Hmmmm...Can't figure why the word filter edited out b u g g e r...
Re: Rampage [Re: tboomer] #1407934
07/13/13 01:35 PM
07/13/13 01:35 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Mike, I feel your pain....
on a positive note, fixin stuff in the garage is a lot more fun than fixin it in a pit spot at the race track any old day
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Rampage [Re: B3422W5] #1407935
07/13/13 01:42 PM
07/13/13 01:42 PM
You got that right
Re: Rampage [Re: MR_P_BODY] #1407936
07/14/13 05:46 PM
07/14/13 05:46 PM
Damn I hate porting iron heads... I now know why I
had different stuff on one of my W-2 heads... when I
bought them both they were SUPPOSE to be econo long
valves... one is the other is standard.. well now I'm
porting 1 new long valve head to match the other...
damn I hate MP and their wrong parts... yet this head
worked for 1000 passes or more the rockers on the on
the standard head with long valves the springs were
rubbing and was eating them up... I do have spare
rockers so I have to get this head ported to get it on
plus I need to cut the seats.. at least I can do
all this myself... this car HATES ME.. but I would
rather do it now and not break down on DW... this is
getting REAL OLD... this is about the 6th time I got
the wrong labeled parts from good old MP
Re: Rampage [Re: MR_P_BODY] #1407937
07/14/13 06:03 PM
07/14/13 06:03 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Sure hope this motor works out Mike you have had your fair share of bad luck with this build.
Re: Rampage [Re: Darryls-Demon] #1407938
07/14/13 06:09 PM
07/14/13 06:09 PM
If I had time I would pull the 416 apart and have the
lifter bores bushed and put it back together... if
I would have done that when I first pulled it out I
would be close to getting it back in now.. but I thought
it was gonna be a quick freshen up on the 396
