Shock Absorber Recommendation - "04 Ram 2500 4 x 4 #1407553
03/24/13 11:06 AM
03/24/13 11:06 AM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
It's probably past time I replaced the OEMs on my truck. Most miles are highway miles, with little to no off-roading. Towing and heavy loads are seldom occurrences. Truck now has 138K miles,and I want to replace shocks before I get new tires. Anyone care to make a recommendation?
yeah, I here the register ringing...
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: 74Charger] #1407554
03/24/13 11:42 AM
03/24/13 11:42 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Bilstein
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: JohnRR] #1407555
03/24/13 11:54 AM
03/24/13 11:54 AM
Locomotion Offline
Locomotion  Offline
I just replaced mine on a '04 Dodge dually with Bilsteins after 112,000 miles. Researched some opinions on Dodge truck sites and got mine from here:
Shock Warehouse - Florida
But it never hurts to shop around, like Summit, etc.
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: Locomotion] #1407556
03/24/13 12:23 PM
03/24/13 12:23 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
bilsteins are the best hands down
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: pnypwr] #1407557
03/24/13 06:39 PM
03/24/13 06:39 PM
IN
ahy Offline
ahy  Offline
IN
If you liked the OE shocks, you might check your Dodge dealer. I was in a similar situation with a Durango at 100k. The factory replacement shocks were a bit more costly than generic replacements but less than the high end speciality shocks. I liked the OE and they lasted 100k so that's what I used for replacement.
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: 74Charger] #1407558
03/25/13 01:20 AM
03/25/13 01:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I replaced the shocks on my 2005 Ram 3500 with the yellow Bilsteins (4600 Series.) They seemed a bit softer (ride) than the stock shocks?
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: 451Mopar] #1407559
03/26/13 10:07 PM
03/26/13 10:07 PM
Creedmoor, NC, USA
Creedmoor, NC, USA
if you were doing it over, would you go the same route?
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: 74Charger] #1407560
03/28/13 02:04 AM
03/28/13 02:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm happy with the Bilsteins. I just noticed they seemed a bit softer than the stock shocks. That is fine with me as most of my driving is on-road with some towing.
The stock ride would sort of bounce over bumps without much suspension movement, and the Bilsteins seem to absorb the bumps with more suspension travel.
I think the Bilsteins I have (the yellow ones) give a smoother ride, but I'm not sure how they would be off-road. On washboard dirt roads they seem to work fine too.
The reason I changed the stock shocks was the rear axle would bounce around more than usual when driving down a bumpy road. The new shocks seem to handle that road just fine.
I hope that helps? Anyhow, I would say that I would use the Bilsteins shocks for my application again.
I think if I was looking for a stiffer, more off-road shock, I would look at the adjustable Rancho (I think 9000) shocks. A friend has them on his 2002 Ram.
Re: Shock Absorber Recommendation - "04 Ram 2500 4 x 4 [Re: 451Mopar] #1407561
03/29/13 10:55 AM
03/29/13 10:55 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Bilsteins here too.
The stock shocks are valved differently and result in a harsh ride. The bilsteins can't be considered soft yet the ride is much nicer with no loss of handling (brobably better) during driving the twisties or towing.
I bought through eshocks.com. If your truck is lifted you will need the silver ones, otherwise the yellow for stock ht.
