SB Kick down linkage #14074
01/18/05 09:33 PM
01/18/05 09:33 PM
Anonymous OP
Anonymous OP
The 340 in my 70 duster will soon be having an Edelbrock performer manifold with a 1" spacer atop. The kickdown linkage rod will be too short. Will the rod from a big block be longer and shaped well enough to work?
Re: SB Kick down linkage #14075
01/18/05 10:17 PM
01/18/05 10:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
first I will ask you why you would use the performer over the stock intake. About the only advantage you will get is it is lighter. From what I have seen the performance won't be much better. You will have to lengthen (splice in) the rod from the carb to the belcrank and rebend to get the right angle for your spacing to get the proper adjustment. Remember to use the light spring to pull it into constant contact with the carb. pin.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: SB Kick down linkage [Re: MoparforLife] #14076
01/19/05 03:47 AM
01/19/05 03:47 AM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Ditto on the mods to the rods /likange,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: SB Kick down linkage [Re: bigD] #14077
01/19/05 11:23 AM
01/19/05 11:23 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The hardware stores carry a hollow nut about 2" long that screws on the existing linkage then you buy a piece of all- thread the right size and cut to fit and install the sloted piece of linkage that attaches to the carb on the end of the all-thread. The nut will give some adjustability for finite tweeks.
Re: SB Kick down linkage [Re: stumpy] #14078
01/19/05 11:42 AM
01/19/05 11:42 AM
Anonymous OP
Anonymous OP
Why the performer intake? Well, I believed the ad in the mopar car mags back 8 years ago or so when Edelbrock was showing significant increases in hp and torque when the performer intake and carb were teamed together. As to whether it helped, that's anybody's guess. Bouchillon makes a kickdown linkage system, but it's megabucks and I'm hoping to find a cheaper way. Thanks for the tips. I may just weld a 2" piece of rod steel in the middle. I was even thinking of cutting the rod in half, then slipping a hollow steel rod over the break, adjusting it to the correct length, then crimping it. That way I could always restore it to its original length. I was just hoping that perchance the BB rod was sufficient. Guess it's not.
Re: SB Kick down linkage #14079
01/19/05 03:20 PM
01/19/05 03:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
This is what I used on my 360 van. It cost $2.45 and 20 minutes work.
1428459-kick down.jpg (175 downloads)
Re: SB Kick down linkage [Re: stumpy] #14080
01/19/05 04:16 PM
01/19/05 04:16 PM
Anonymous OP
Anonymous OP
YOu gotta realize most car ads, even in mopar specific magazine, use SBC test data.
While I am not familar with the specific ad you are talking about it's possible this is the case.
I remember an ad for one of the aftermarket SBC heads that compared their head on a 350 versus a stock 305 head on a 350.
Hmm, let's put a small head on an engine that it never came with then show big gains. Yeah, that'll get the suckers.
You gotta take ads with a big old grain of salt.
Thor
Re: SB Kick down linkage #14081
01/19/05 04:32 PM
01/19/05 04:32 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Thor
Huh?? What does this have to do with kickdown linkage?
Re: SB Kick down linkage #14082
01/19/05 05:02 PM
01/19/05 05:02 PM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
I'm running an Airgap on my 360. All i did was weld a 1" extension on the rod coming up from the bell crank and made adjsutemnts from there.
Abe Lincoln
Re: SB Kick down linkage [Re: dart4forte] #14083
01/19/05 05:09 PM
01/19/05 05:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
"Huh?? What does this have to do with kickdown linkage?"
It has to do with the original post about why the change was necessary.
Re: SB Kick down linkage [Re: stumpy] #14084
01/19/05 05:21 PM
01/19/05 05:21 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Ahhhhh, okay. I see the point. My bad, carry on.
Re: SB Kick down linkage [Re: Hotwheelsjr] #14085
01/19/05 05:34 PM
01/19/05 05:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Okey Dokey.
Re: SB Kick down linkage [Re: stumpy] #14086
01/19/05 11:15 PM
01/19/05 11:15 PM
Anonymous OP
Anonymous OP
Yeah, I can see how easy it is to modify the linkage rod that goes to the carb. But specifically I was asking about the rod that comes up from the tranny to the bell crank which will have to be mounted on an extended height bracket. Doesn't that one have to be lengthened and will a BB rod work? Heck, maybe I only need to lengthen and reshape the carb rod and the bell crank takes up the difference in height for the tranny rod. Sorry to ramble on with this thread but I'm eager to fire her up and this is the last hurdle.
