Re: Map light only works with doors open???
[Re: Hoop]
#1407339
03/23/13 10:03 PM
03/23/13 10:03 PM
RapidRobert
as said either the socket side case of the bulb (if a single contact base) or one of the base contacts (if a dual contact base) bulb needs to be grounded at all times then you have simply power to the switch/thru it to the bulb. Not sure how the map light is connected to the dome light tho so I might be missing something
[Re: RapidRobert]
#1407340
03/25/13 11:27 AM
03/25/13 11:27 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
Since the dome light system and map light turns on via door Jam Switch, map light BULB must be isolated from Chassis ground.
Positive source to bulb in both ( dome and map ) is constant from batt
The Map light switch should provide the ground when dome light is turned off.
How it works ? switch must have two positions... one what closes the circuit with Dome light system alowing to turn on when Dome light lights up ( via dimmer wheeel or door switch ), and the other one what cuts this circuit and closes the circuit with chassis ground FEEDING the switch, not the bulb socket.
being this the truth, the map light bulb should be two contacts one filament just exactly like the 1004 dome light bulb
[Re: NachoRT74]
#1407341
03/25/13 11:43 AM
03/25/13 11:43 AM
NachoRT74
Valencia, España
this is how should work the Map light
( forgott to add on diagram, the yellow wire signal is of course negative )
[Re: Hoop]
#1407343
03/30/13 04:52 PM
03/30/13 04:52 PM
NachoRT74
Valencia, España
to support the ground strap deal... here is what I found on an ebay auction that would make the switch having just two prongs instead three however, this is also from an E body
