Kevko pan & pick up question #1407241
03/23/13 06:15 PM
03/23/13 06:15 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Since my primary motor (vintage circle track racing) is kaput, I am trying to rush a back up engine into service. I put a Kevko rear sump oil pan on it, along with their pickup. Their pickup plugs the normal hole and runs the pickup off the cover. The original cover inside has two carved out areas, the Kevin cover is smooth. Just being careful, is this a problem at all?
Re: Kevko pan & pick up question [Re: BillNC] #1407242
03/23/13 08:53 PM
03/23/13 08:53 PM
I dont think so but for peace of mind you might go to www.moparchat.com then scroll down to & click on "circle track chat" & post there. I've wanted to get that setup, if it's 1/2" NPT? I'm assuming it's made for the OE pump body & not just as a replacement part for the Kevko pump which if so would further confirm there's no problem. Might be for lube or anticavitation.
Re: Kevko pan & pick up question [Re: RapidRobert] #1407243
03/23/13 08:57 PM
03/23/13 08:57 PM
NC
BillNC Offline OP
BillNC  Offline OP
NC
Yeah it fit the pump on the engine just fine.
Re: Kevko pan & pick up question [Re: BillNC] #1407244
03/23/13 09:07 PM
03/23/13 09:07 PM
I wanna make one out of a piece of thick flat stock & tap it for NPT in the right spot. Is the Kevko piece 1/2 NPT? I bet it's pricey. EDIT While in there you might peruse Sanborns oiling & cooling mods that are in a sticky at the top of the page (for good reason). He's one of the countries' foremost SB oiling & cooling experts & alot of that info can be adapted to BB's as well
Re: Kevko pan & pick up question [Re: RapidRobert] #1407245
03/24/13 10:15 AM
03/24/13 10:15 AM
pennsylvania
poboyengineering Offline
pennsylvania
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Kevko pan & pick up question [Re: poboyengineering] #1407246
03/24/13 10:16 AM
03/24/13 10:16 AM
pennsylvania
pennsylvania
sanborn is the man for oiling.
