1970 Challenger kick panel insulation
#1407171
03/23/13 04:53 PM
03/23/13 04:53 PM
Posts: 433 Wausau Wisconsin USA North Ame...
radiatorman
Hi Guys, Can anyone tell me if I have the insulation pieces positioned correctly on the kick panels? And where the heck do the two other pieces of backed insulation go? I marked one "d kick panel" and purposely left the screw in it to remind me where it goes (5 years ago) but I can't remember now. Any good pictures out there?? Thanks, Bob
Re: 1970 Challenger kick panel insulation
[Re: AAR#2]
#1407178
01/04/14 03:30 AM
01/04/14 03:30 AM
Posts: 401 California, USA
filmsurgeon
California, USA
Since Alaskan T/A has the kick panels covered, the pieces you currently show in the kick panels should be installed in the dash structure (Just above the kick panels) you'll see them in the upper corners of the photo's I have attached. I can outline them if you need but think you'll find it pretty self explanatory, if not, let me know.
Doing my insulation now. The REM kick-panel kit I got several years ago has 3 pieces; the 2 larger pieces which is self explanatory, and the piece for the backside of driver-side kick panel, not one the for the passenger side. Any ideas where I can get the passenger side piece? How were they secured to the backside of the kick-panels? Also, does anyone know if the two oddly shaped pieces that go "above the kick panels" (as AAR#2 pictured) are being reproduced? Thanks for the help.
[Re: AAR#2]
#1407180
01/04/14 05:03 PM
01/04/14 05:03 PM
filmsurgeon
California, USA
I sent all my pieces in to Detroit Muscle and he was nice enough to correct and cut new pieces that match my originals. Unsure if this is the standard cut for him now but he should have mine on file
Contact him, I'm sure he can hook you up
Thanks. I contacted Jim via email last night. I have purchased DMT stuff before, and have worked with Jim on a couple of my special needs. Hopefully, he can help. I know he is always very busy.
