Re: Rear Wheel HP vs Flywheel HP
[Re: MaxHeadroom]
#1407102
03/23/13 01:59 PM
03/23/13 01:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Turbo engines are a little hard to predict the losses on but if its that bad its most likely a conv issue... no one would loose 50%(or there abouts)... and is the dyno number real or just some real happy dyno but it is likely the conv (blowing right through it)
[Re: AndyF]
#1407106
03/23/13 07:03 PM
03/23/13 07:03 PM
Posts: 145 North East
MaxHeadroom
North East
Are you asking a general question or about a particular car? There can be any number of things wrong with a specific car.
There are fairly good rules for figuring out drivetrain loss.
Wanted to know in general, but was looking at a specific car and trying to figure out why its performance does not match up with Dyno reading. Its a Procharged stroked 440 and dyno showed 1386Hp, but performance wise it is an 11 sec car, when it should be 9 for sure. Either there is something wrong with the setup or the dyno readings are off, can't see losing that much power.
[Re: MaxHeadroom]
#1407107
03/23/13 07:19 PM
03/23/13 07:19 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
I know Ford allocate around 17% on their factory automatic drive trains. My experience with 904/727 , 8.75 and a 3500 stall shows between 20 and 22%. Tire compound and tire diameter can also make a significant difference. New LX Auto cars reportedly lose around 18-20% due to tire diameter and the Nag1 slushbox Cant help you with any turbo data.....
[Re: Moparmal]
#1407108
03/23/13 08:17 PM
03/23/13 08:17 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You only lose what your driveline absorbs. You cannot assign a pecentage. If I have a 500hp engine in my car, than take it out and replace it with a 1000hp engine, the driveline is not going to take more to drive. Some people say you lose 20% to your driveline. How would that workout with my example?
[Re: TRENDZ]
#1407109
03/23/13 09:00 PM
03/23/13 09:00 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
convertor slippage, the only real way to know what the actual lose is would be to have a driveshaft pickup and see what the percentage is. even then there are still a bunch of variables. there is a reason people don't race dynos. they are tuning tools and to be used as such
[Re: prochargedhemi]
#1407110
03/23/13 09:24 PM
03/23/13 09:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have read about a 500 hp eng in a basic street car that had about 420 at the wheels. Thats just a general idea as of course it depends on what driveline setup you run. But I would think on rear wheel drive cars in the 400 to 600 hp area anywhere from from about 60 to 100 hp driveline loss is about normal ? One calculator rated my car at about 600 flywheel and 525 at the wheels. Ron
[Re: 383man]
#1407111
03/23/13 09:34 PM
03/23/13 09:34 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
the harder & faster you try to turn something, more friction is produced.. thats why it is a % loss
[Re: TRENDZ]
#1407112
03/23/13 09:35 PM
03/23/13 09:35 PM
Moparmal
I agree - and the faster you rotate the driveline, the greater in frictional and inertial losses...so the % doesn't remain constant.
Unfortunately you took my examples as being "generic",...when my intention was to simpy provide some examples related to some more common drivetrain scenarios
[Re: 383man]
#1407113
03/23/13 09:38 PM
03/23/13 09:38 PM
Moparmal
Ron..I know of one engine builder that swears you can almost set your clock at 110 HP for a small block driving a 727, a 4000 stall and a 9" on a 27" tire.
He also believes around 80Hp for the same scenario with a 904.
[Re: Moparmal]
#1407114
03/23/13 09:52 PM
03/23/13 09:52 PM
Posts: 1,481 Outside
thedriver
Outside
Ron..I know of one engine builder that swears you can almost set your clock at 110 HP for a small block driving a 727, a 4000 stall and a 9" on a 27" tire. He also believes around 80Hp for the same scenario with a 904.
my 340/727/10" loose converter was right in that range. One of the reasons I'm converting to stick. All this hp costs money, disheartening when the driveline takes it away.
1973 challenger Dana. 4 speed. Low deck.
[Re: MaxHeadroom]
#1407115
03/23/13 11:51 PM
03/23/13 11:51 PM
Posts: 4,210 New York
polyspheric
New York
How to tell when your 727 is consuming 500 hp: the car is a giant fireball.
Boffin Emeritus
[Re: MaxHeadroom]
#1407120
03/30/13 07:42 PM
03/30/13 07:42 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
18 to 22% Manual 24 to 28% Auto Lowly, but very consistent example: I've had 318's with 4 speeds, 904's and 727's and there's no doubt in my mind: the 727 is a power-robbing turd. They have purpose: I can't break one.
Mo' Farts
Moderated by "tbagger".
