Removing fan shroud studs? #1407028
03/23/13 10:45 AM
03/23/13 10:45 AM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
Are these welded in?
Had my radiator re-cored ('69 C Body) modded to fit '71 B Body and asked the shop to remove the studs while it was apart. They just cut the threaded portion off before re-assembling
What's the best way to get these off. Don't have room for a grinder in there.
Re: Removing fan shroud studs? [Re: roadhazard] #1407029
03/23/13 02:09 PM
03/23/13 02:09 PM
cbusters Offline
cbusters  Offline
The studs have 3 small spot welds under the head. You will have some work to to remove them and repair the welds. I have done some but it was before they were soldered back on the tank.
Re: Removing fan shroud studs? [Re: cbusters] #1407030
03/23/13 02:24 PM
03/23/13 02:24 PM
I'm assuming there ain't room to get a regular (or angle) drill in there. But if so a good hardened bit (cobalt or carbide I forget which) will go thru em like butter
Re: Removing fan shroud studs? [Re: roadhazard] #1407031
03/23/13 04:08 PM
03/23/13 04:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
As said welded , I would drill and tap it if you want to run a bolt into it , I broke a stud off and that's how I repaired it , installing a piece of threaded rod.
Re: Removing fan shroud studs? [Re: JohnRR] #1407032
03/23/13 07:38 PM
03/23/13 07:38 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Thanks for the responses
cbusters & RapidRobert after reading your posts this morning got me to thinking about drilling and tapping for a stud. Then JohnRR comes in and posts just that
Going to try drilling & tapping and if that don't go well or I get lazy I'll tack them with the mig
Not much else I can do except take it back & get disassembled
Here's my shroud repair
https://board.moparts.org/ubbthreads/show...e=5#Post7631529
