Re: 440 RB head gaskets
[Re: stateroadhog]
#1406971
03/23/13 03:05 PM
03/23/13 03:05 PM
Posts: 43,319 Bend,OR USA
Cab_Burge
Has any one used the cometic 3=layer head gaskets with aluminum heads and cast block? Results and opions.
Yes I have, you need to make sure that both the heads and block have the correct or smoother finish, RA # on them for any of the MLS, Multi Layer Steel, nitrile rubber coated gaskest to seal properly and not leak coolant between the heads and block. I learned that the hard way on a new Mopar replacement 426 block I built for a customer, it leaked coolant out of all four lower head corners do to a stock rough deck finish Contact Cometic for the correct RA finish number I've used them since on several B and RB stroker motors that had the correct deck and head surface finsh and they work and seal very well ![](/ubbthreads/images/graemlins/thumbs.gif)
