Cracked BB bell housing...replacement question #1406931
03/23/13 08:35 AM
03/23/13 08:35 AM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
After pulling the 383 out of my 70RR I noticed a crack on the bell housing going from the outside of a bolt hole and across and down the curvature of the housing itself.The new motor will have around 400-450 hp...should I just go with a Quicktime bullet proof housing or find another stock replacement.I was hoping some of you experienced guys would have some advice...thanks
Re: Cracked BB bell housing...replacement question [Re: 70 Roadrunner*] #1406932
03/23/13 10:02 AM
03/23/13 10:02 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
If your bellhousing is the stock aluminum 10.5", we have a heat treated 356 T-6 aluminum replacement, considerably stronger than the factory die cast:
http://brewersperformance.com/proddetail.asp?prod=BH513R
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Cracked BB bell housing...replacement question [Re: 64dodge572] #1406933
03/24/13 07:00 PM
03/24/13 07:00 PM
Maud,Tx
maud Offline
maud  Offline
Maud,Tx
I have a blow proof chromed one for $100 plus shipping , email me at maudmopars@windstream.net
