RCI fuel cells foam or not? #1406165
03/21/13 04:55 PM
03/21/13 04:55 PM
Australia
big_wedge Offline OP
Australia
I looking to install a fuel cell, what do you guys think of the foam filled cells versus the non foam filled cells, any disadvantages with the foam?
Re: RCI fuel cells foam or not? [Re: big_wedge] #1406166
03/21/13 05:46 PM
03/21/13 05:46 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
Depending on how big of a cell you run the foam helps reduce sloshing (sp) and uncovering the pickup
Re: RCI fuel cells foam or not? [Re: big_wedge] #1406167
03/21/13 06:01 PM
03/21/13 06:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The foam breaks down with today's fuels.I have a 5 gallon cell and took out the foam.Since I keep the tank at 4 gallons at all times,I do not run out of fuel.
I have had the foam go bad and go thru my entire fuel system...not fun at all to clean out.
Nautilus Racing-
Re: RCI fuel cells foam or not? [Re: big_wedge] #1406168
03/21/13 06:24 PM
03/21/13 06:24 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Been running an rci with foam for about 5 years.. CA pump gas. No problems here.
Re: RCI fuel cells foam or not? [Re: Exit1965] #1406169
03/21/13 07:22 PM
03/21/13 07:22 PM
michigan woods
imfixinmopars426 Offline
michigan woods
bought a race car w/ foam tank...very soon the foam came apart,and we through the fuel system.....no more foam,please
Re: RCI fuel cells foam or not? [Re: big_wedge] #1406170
03/21/13 07:35 PM
03/21/13 07:35 PM
Locomotion Offline
Locomotion  Offline
I've been using Sunoco Purple race gas for as long as I can remember and never had and issues with the foam, including the Summit 5 gal. aluminum tank that's been in the current car for several years.
I would be mainly concerned with some street gas or some of the more exotic race fuels.
Re: RCI fuel cells foam or not? [Re: Locomotion] #1406171
03/21/13 09:58 PM
03/21/13 09:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
VP C12 and C14. Never had any foam in the filters when we clean them.
Re: RCI fuel cells foam or not? [Re: big_wedge] #1406172
03/21/13 10:42 PM
03/21/13 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
5 gal cell with foam... ran it 13 years with 110 race
fuel and it never hurt the foam... last 4 years with
E-85 and its still in there
Re: RCI fuel cells foam or not? [Re: MR_P_BODY] #1406173
03/21/13 10:45 PM
03/21/13 10:45 PM
ill
dennismopar73 Offline
ill
Take the Foam out!!!
I have had the Foam break down out of 3 new cells,
From now on I just take it out, do your self a big favor!!!
Re: RCI fuel cells foam or not? [Re: dennismopar73] #1406174
03/21/13 10:55 PM
03/21/13 10:55 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
fuel cell in my car been in there for 20 years. 110 racing fuel-pump gas-e85 no problem with the foam.
Re: RCI fuel cells foam or not? [Re: prochargedhemi] #1406175
03/23/13 01:14 AM
03/23/13 01:14 AM
Australia
Australia
seems to be a 50/50 call on the foam
