833 Transmission id-numbers #1406076
03/21/13 01:52 PM
03/21/13 01:52 PM
Moncton, New Brunswick
hemidart1 Offline OP
Can anyone help me out to i.d. this tranny-ie: what year etc..
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406077
03/21/13 02:00 PM
03/21/13 02:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Look for a raised pad on the passenger side of the main case, it'll have the build data stamped in it.
Re: 833 Transmission id-numbers [Re: John_Kunkel] #1406078
03/21/13 02:09 PM
03/21/13 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The numbers posted are basically useless in any kind of identification process ...
That said it looks like the 71 up side cover , also looks like an 82 date code on the cover , so it could be an OD trans
Re: 833 Transmission id-numbers [Re: JohnRR] #1406079
03/21/13 02:12 PM
03/21/13 02:12 PM
ok
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406080
03/21/13 02:14 PM
03/21/13 02:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What info are you trying to find out ?
Re: 833 Transmission id-numbers [Re: JohnRR] #1406081
03/21/13 02:38 PM
03/21/13 02:38 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Looks like a early 80's alum main truck/van overdrive
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: 833 Transmission id-numbers [Re: Dan Brewer] #1406082
03/21/13 02:56 PM
03/21/13 02:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Assuming it's never been messed with
Re: 833 Transmission id-numbers [Re: JohnRR] #1406083
03/21/13 08:38 PM
03/21/13 08:38 PM
I am looking for my Charger-the guy is selling it with an adapted bell housing to fit a Chevy. I would ditch the bell housing if it is a correct trans.
more pics:
[image]
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406084
03/21/13 08:42 PM
03/21/13 08:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
In the 80's GM put the A833 in Chevy trucks. I have no idea what they did you make it work but I would at the least make sure the input shaft is Mopar specific and not Chevy.
Don't be the exception.
Re: 833 Transmission id-numbers [Re: hemidart1] #1406085
03/21/13 10:33 PM
03/21/13 10:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you looking for an overdrive trans because that is what that one is as pointed out by rapidfire.
That APPEARS to be a chrysler input shaft , if it's a trans you want to buy I would get a pilot bushing and bring it with you when you go to the transmission and make sure it fits properly.
Re: 833 Transmission id-numbers [Re: JohnRR] #1406086
03/22/13 12:10 AM
03/22/13 12:10 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
The GM A833's use a 10 spline input and the cases are GM specific. It doesn't even look like a mopar trans except the side cover. The trans in questions is mopar.
Re: 833 Transmission id-numbers [Re: Dan Brewer] #1406087
03/22/13 07:59 AM
03/22/13 07:59 AM
I was looking for a regular 833 so I am glad I posted the pics.
Thanks for helping me out on this!
1967 Hemi GTX
1969 Chrysler 300
Re: 833 Transmission id-numbers [Re: hemidart1] #1406088
03/22/13 09:21 PM
03/22/13 09:21 PM
MoPar Offline
MoPar  Offline
Looking at the picture with the shifter near by, appears to be a 6353 shifter with the grease fitting, my best guess would be a overdrive truck/van trans.
