Page 2 of 3 1 2 3
Re: New Toy [Re: MR_P_BODY] #1405485
03/21/13 12:22 AM
03/21/13 12:22 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
That's a really cool score Tig, I had no idea they made RHD Barracudas. Pics would be great!
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: New Toy [Re: topside] #1405486
03/21/13 03:53 AM
03/21/13 03:53 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Given that US cars had their motors shifted to the right, is yours shifted to the left, or is the column shaft a really tight fit in the engine compartment?
Interseting as I never really thought about that with RHD. Ron
Re: New Toy [Re: MR_P_BODY] #1405487
03/21/13 07:49 AM
03/21/13 07:49 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
It's been painted. Front Wings (fenders) are very good condition, bonnet (hood) and boot (trunk) have minimal rust.The majority of the trim is good. It's quite solid. Only real problem area is the rear quarters. They have some filler (bondo) in. A new pair of these and it will be a really good car.
Hi Mick. Not planning to do much at all on this. Just a mild small block daily driver with occasional strip use. Though we are wondering about those SB rpm heads for sale on the MMA board, where will that lead us though?
Getting new bumpers and some small bolt pattern Cragars for it and a Formula S stripe in Dark Blue. Probably just run it around as is 'till we want to do the body work.
Re: New Toy [Re: Tig] #1405488
03/21/13 08:24 AM
03/21/13 08:24 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
A few more.
Re: New Toy [Re: Tig] #1405489
03/21/13 05:16 PM
03/21/13 05:16 PM
Finland
mafo Offline
mafo  Offline
Finland
Plenty of room for the drysump pump there...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: New Toy [Re: mafo] #1405490
03/21/13 07:19 PM
03/21/13 07:19 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Beautiful car love the color
Things sure look backwards on a RH driver
Re: New Toy [Re: roadhazard] #1405491
01/08/14 08:20 PM
01/08/14 08:20 PM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Project is still ongoing but a lot of thing's are coming together now.
Re: New Toy [Re: Tig] #1405492
01/10/14 01:33 AM
01/10/14 01:33 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
koool!
Re: New Toy [Re: 70blackfish] #1405493
01/10/14 01:49 AM
01/10/14 01:49 AM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
That firewall is wacky! You got a close-up of the console? It looks like a 69. I have an Aussie Ute and nothing in the engine bay looks the same.
JB Rhinehart, Realist
A-Body's RULE!
Re: New Toy [Re: Rhinodart] #1405494
01/10/14 08:12 AM
01/10/14 08:12 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
A pic of the centre console?. How different is the engine bay? Pacemaker do headers for Aussie Valients and Chargers, just wondering how the fit would be
Re: New Toy [Re: Tig] #1405495
01/10/14 08:52 AM
01/10/14 08:52 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Tig that is nice!
Re: New Toy [Re: Tig] #1405496
01/10/14 08:56 AM
01/10/14 08:56 AM
Australia
big_wedge Offline
big_wedge  Offline
Australia
Aussie pacemaker headers??? the fit would be fine and they are an easy header to install and remove
Re: New Toy [Re: big_wedge] #1405497
01/10/14 09:13 AM
01/10/14 09:13 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Good to know, as you can see I've got some block huggers to try. Keeping my options open. I emailed pacemaker a while back, asking if they would fit, got no reply They are also quite expensive to ship to the UK.
Re: New Toy [Re: Tig] #1405498
01/15/14 03:15 PM
01/15/14 03:15 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Cool! Thanks for posting the underhood pics.
Re: New Toy [Re: 446acuda] #1405499
01/15/14 11:02 PM
01/15/14 11:02 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
whats the steeringbox and idler arm bolted to ?
Re: New Toy [Re: Cheatham] #1405500
01/15/14 11:14 PM
01/15/14 11:14 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Looks like the same setup the Aussie cars used, and they bolt to the frame rail. (with some through-the-rail crush tubes)
Some of them would crack the rails on the bottom side where it mounts, so always good to check them out there.
A common mod in Oz is a modified K frame to use a rack and pinion. I put one in my old Charger, was a nice setup. (they use a common Holden Commodore rack)
Re: New Toy [Re: OzHemi] #1405501
01/15/14 11:17 PM
01/15/14 11:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Here is VH/VJ Valiant from Oz frame area where the steering box mounts. This was my Charger when I had the K frame out to swap to the rack setup.
Re: New Toy [Re: Tig] #1405502
01/15/14 11:20 PM
01/15/14 11:20 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Maybe try emailing http://www.dodgecity.com.au/ for the extractors ? They deal with most of the Oz companies. (I delt with Paul before and got my rack conversion from him as well years back)
Re: New Toy [Re: Rhinodart] #1405503
01/15/14 11:25 PM
01/15/14 11:25 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
It is odd...sort of like a hybrid LH/RH sort of one. Not just a firewall from an Oz Mopar at least.
The Aussie cars never had the firewall bulkhead connector like his does, they just went through a rubber gommet near the heater hoses.
Re: New Toy [Re: OzHemi] #1405504
01/16/14 12:25 AM
01/16/14 12:25 AM
ontario
Clockwork Offline
Clockwork  Offline
ontario
Nice car!
572ci B1 7.90 172MPH
Page 2 of 3 1 2 3
